Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Sign in using an external account
Register Forgot Password?
Master key won't start car
Thread Tools Search this Thread Display Modes
Old 08-01-14, 11:50 AM   #16
tarzan17
Trader Score: (0)
It is not looking good. The low hanging fruit didn't solve it - there using laptop to diagnosis now. Tech could not reprogram key I think and has moved car into bay.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
tarzan17 is offline   Reply With Quote
Old 08-01-14, 11:53 AM   #17
salimshah
Trader Score: (0)
Guys it is not the electronics (chip) in the key. There is magnetic slug which is embedded in the shell (remains behind even if you remove the electronic module... also battery or no battery in the key does not affect the imobilizer).
The signature of the flux is registered in the car's ecu as allowed to start. Master key allows new signature to be stored in the ecu.
I hope it helps.
Salim
salimshah is offline   Reply With Quote
Old 08-01-14, 11:54 AM   #18
salimshah
Trader Score: (0)
See if you can ask the tech to disable the imobilizer ,,, you loose the security but it might be an acceptable solution.
Salim
Old 08-01-14, 12:23 PM   #19
tarzan17
Trader Score: (0)
They said it was not possible and cannot disable the immobilizer. Saying the only option is to replace the ecu. They also said they don't have the ability to tell if the key is transmitting anything. The flashing security led has to be off before the car will start. Mine is flashing even with key inserted.
Edit: will probably get it towed back home since may not be worth to fix. They did mention that it maybe possible to disable immobilizer aftermarket but they don't do it at dealership.
Old 08-01-14, 12:52 PM   #20
tarzan17
Trader Score: (0)
Damn. New twist - service advisor offered me service to reprogram ecu with new key by someone not affiliate d with Lexus for $800 as opposed to Lexus replace ecu and parts for around $1500. Caveat is that the reprogramming must be done at lexus even though he doesn't work for them. Gonna get it towed back home.
Edit: service advisor said parts guys know a locksmith that can reprogram and cut key - my guess why it has to be done at Lexus is that locksmith needs Lexus equipment to do job. Also mentioned it was a lot of work since they have to remove ecu etc.
Edit 2: they don't have any idea what happened - this is my concern about fixing since it can happen again. Good part is that they did not charge for diagnosing.
Old 08-01-14, 02:56 PM   #21
AnthonyMtz
Trader Score: (0)
Wow you have certainly have "gone to hell and back" with this issue...at this point I would maybe suggest that you look on ebay (possibly other sites) for a used ecu with remotes that go to it you would bee looking anywhere from 300-600$ that really sucks!
AnthonyMtz is offline   Reply With Quote
Old 08-01-14, 03:17 PM   #22
AnthonyMtz
Trader Score: (0)
Hey bud I found this ecu for you on ebay all you got to do is change the ecu and magic should happen it comes with a master key so you can reprogram the valet key and key card, also if you want to program more you can (since this ecu has the master key) it's 360$ witch is pretty good here is the link check it out Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=301256273797&alt=web
Old 08-01-14, 03:22 PM   #23
tarzan17
Trader Score: (0)
Found this on Kijiji - a lot cheaper than dealership. I'm going to give this a go.
See screen capture in case link is dead.
http://www.kijiji.ca/v-other-auto-pa...ationFlag=true
Old 08-01-14, 03:40 PM   #24
tarzan17
Trader Score: (0)
Thanks AnthonyMtz!
I'm not sweating it, this is a 1st world problem . I'm waiting to hear back from the Kijiji guy - but will definitely consider that ebay item (which comes with everything) if it doesn't work out.
Old 08-01-14, 03:46 PM   #25
AnthonyMtz
Trader Score: (0)
Great glad it helped! 120 is a steal! The only reason why the eBay one cost 360$ is because it comes with the whole steering assembly And the key ring I am really hoping this works for you! All of us here on CL get a little pain in our hearts when we see people struggling with issues but the best of luck to you!!
Old 08-30-14, 09:58 PM   #26
tarzan17
Trader Score: (0)
Car is up and running again !
Great service and highly recommend Enny and his company above - although they are crazy busy. He is a former Toyota/Lexus automotive locksmith, very knowledgeable and loves what he does.
They came to my house last week and could not get the car started -discovered that the key was missing the immobilizer chip (gray magnet looking piece) and that the ECU had problem reflashing. So they took the ECU and key with them to work on.
Came back late tonight with reflashed ECU (had to desolder and plug new (IC900?) chip in order to reflash). Installed ECU then reprogrammed with (3) keys - (2) dummy and my one key. Car started up like a champ.
Total $160.
Still find it strange that the key was missing the immobilizer piece. Must of popped out when exchanging key shells. I do remember that the black membrane was stuck to the plastic shell in one area so that the two pieces became separated (membrane and electronic case) - so word of advice to those moving electronics to new keyshells - do the switch in sterile work area where you would be able to detect the immobilizer piece falling out.
Finally, for those who are wondering, all is not lost when you lose your one and only master key. You can get the ECU reflashed to virgin, and then reprogrammed with a new master key.
EDIT:
Thanks to AnthonyMtz and the legendary salimshah. salimshah FYI Enny confirmed what Lexus said in that there is no way to disable the immobilizer although if that option was available, I would have gladly taken it.
Similar Threads
Thread Thread Starter Forum Replies Last Post
ECM Master Key/Valet Key Mixed Success Z07 RX - First Generation 8 02-06-14 03:44 AM
Yes, there is such a thing as a non-remote master key LarryParker Maintenance 12 08-04-10 05:50 PM
HELP - Lost My Key!! gcam77 GS - Second Generation 8 07-07-08 08:23 AM
SC430 Key Programming Issue: Too many? scdroptop Lexus Audio, Video, Security & Electronics 1 09-07-06 11:03 PM
Programing Master Key SC430 easyrider SC 430 3 12-07-05 03:04 PM
Tags
broken, car, key, lexus, start, wont
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
