Oil filter question...
Old 06-30-14, 08:45 AM
  #31
imherenow
imherenow's Avatar
yup the room is very small ..so i do it from top and rotate it inch by inch. sure it takes time..plus once the filter has been rotated enough all you need is by hand to finally remove it
Old 06-30-14, 12:59 PM
  #32
fastnoypi
fastnoypi's Avatar
74.5mm oil filter wrench cap paired with a flexible 3/8 ratchet handle works great, from the top or bottom.
http://www.harborfreight.com/3-8-eig...het-96369.html
Old 07-03-14, 12:13 PM
  #33
Z07
Z07's Avatar
I use Pure One filters from Purolator. These filters have a textured finish not unlike a fine emery cloth. This allows me to spin them on and off by hand with no tool. The filter pliers a few posts up would work fine if a slightly longer filter were used. But a slightly longer filter may require that or the strap type wrench due to clearance issue with the filter cap type.
Old 07-29-14, 07:42 AM
  #34
lexina
lexina's Avatar
I can confirm the information is INCORRECT, whether the engine was COLD or FROZEN or Parked Overnight, oil will spill when the oil filter is removed. It was a mess, i wished i could have been more cautious. Without working on the underside, there is no way you can clean the oil spill.
So, people, be very very careful when you work on your car at your discretion, use the forum information as reference at your own risks. Someone could try to say something to sound good and to prove their points, but that is not reality. Remember, oil will always in the filter, no matter how many years the car has been immobilized. A horizontal oil filter position will NEVER drain oil empty by itself.
Originally Posted by BertNelson
When I do it the engine is cold. So ALL the oil has drained out of the filter back into the engine. That is 1 reason why I do it cold. Then, even with EXTREMELY large hands I am able to flip the filter right side up and remove from the right side. That's my plan and I'm sticking to it.
Old 08-04-14, 04:30 AM
  #35
pilot2
pilot2's Avatar
The inards of a K&N2009 and Toyota 90915-YZZD3 filters...
TOYOTA 90915-YZZD3 FILTER:
"You pays your money and you takes your choice."
Old 08-04-14, 08:24 PM
  #36
aznlapin
aznlapin's Avatar
For the second pic, what's the difference between the two K&N filters?
Old 08-05-14, 12:37 AM
  #37
artbuc
artbuc's Avatar
Originally Posted by lexina
...Better filtering means slow oil flowing...
I think this is wrong. The oil pumps are positive displacement meaning they deliver the same volume independent of back-pressure.
Old 08-05-14, 06:11 AM
  #38
pilot2
pilot2's Avatar
One is made in the USA the other Mexico.
Old 08-05-14, 06:23 AM
  #39
pilot2
pilot2's Avatar
Originally Posted by ClassicSC3
... Should I go with Toyota, Lexus or an off the shelf like Purolator or Napa Gold...
From what I have read, any of those brands will do a good job. Some prefer the K&N because it has a nut type fitting at the end of the filter which can make removal easier. Myself, I opted to buy a case of the Toyota 90915-YZZD3 filters at $4.00 each; this filter, like the K&N, is a bit longer and has more filter media but it does not have the nut type fitting on the end. Removal of the Toyota filter is still easy if you use an inexpensive end-cap oil filter wrench:
Old 09-16-14, 05:01 AM
  #40
pilot2
pilot2's Avatar
Default Epilogue on filter removal
Just changed the oil, working from the top-side, contrary to concerns some had expressed, there is no problem accessing and loosening the longer Lexus oil filter, 90915-YZZD3, when using an end-cap oil filter wrench. The oil was changed HOT, but an old leather glove was utilized which completely prevented a hot manifold encounter.
The filter was loosened just enough to let a thin stream of oil come-out the bottom, made next to no mess and no oil touched the plastic fairing underneath. The filter was then fully screwed-off from the top, then rotated so the drain hole was facing-up and then lowered and set on the plastic fairing below (the screws for which had already been removed); it was then easily removed from the bottom.
What in most cars would be a 10-minute oil change was a 25-minute oil change. As this was only my second RX oil change, hopefully the time will get shorter with practice.
gtsnake
07-09-19 08:59 AM
moya
29
06-09-06 11:48 AM
81corolla
05-01-06 09:38 AM
rx300force
02-16-04 11:17 AM
gebo
Maintenance
12-24-02 10:36 PM
Quick Reply: Oil filter question...
