Help with heater blower
Old 02-15-14, 09:36 AM
tlg588
tlg588's Avatar
Default Help with heater blower
Hi All,
This forum is great and has been a big help.
My heater - A/C blower quit. I have searched the forum for this issue and started working on the problem but I need some additional advice before I shell out the $ for a new control module.
I tested the voltage going from the control module to the blower and got a reading between 9 and 10 volts. The voltage changes very little if at all when turning the fan speed control ****.
I hooked the blower direct to the battery and it worked.
So is the control module bad? should I get some rotation from the blower at 9 volts?
Thanks
Tim
Old 02-15-14, 02:06 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,099 Likes on 989 Posts
If you know the pin-outs, you can remove the controller and jump the +12v to the module to B+ of the motor. This would eliminate any wiring issue and fuse issue.
Voltmeter tests do not show the impact of current draw. A better way would be to put a +12v bulb of about 10watts for blower ckt to verify. You can even leave the blower in circuit and check voltage .,,, (it would be close to 0 ,,, I think)
Salim
Old 02-15-14, 03:44 PM
tlg588
tlg588's Avatar
I found an used module at a salvage yard for $65. I installed it and the blower now works fine.
Micholz
05-21-15 01:28 PM
Gs300feen
09-05-14 06:00 PM
deviat
SC- 1st Gen (1992-2000)
15
12-28-10 12:58 PM
flyboicus
11-02-06 08:49 AM
b1ackhawk
22
02-09-06 07:32 PM
Quick Reply: Help with heater blower
