Autobox jerking and bucking after fluid change
Old 01-18-14, 09:11 AM
JemP
JemP's Avatar
Took the RX for a drive today, if I dont give it any real load it goes up and down through the gears without problem, engaging and disengaging overdrive all works correctly. I can also work it up and down the box using the manual buttons too. But the minute I try and floor it, it bucks!
Didnt have a chance to check for fuses to get the obd thing working as it was raining too much, try tomorrow
Old 01-19-14, 07:00 AM
kalali
kalali's Avatar
This may be a pure guess but I had a similar issue with another vehicle and it was a faulty throttle position sensor. Not sure if this would apply to the RX.
Old 04-06-14, 06:34 PM
JemP
JemP's Avatar
Right, I havent had much chance to work on this due to overseas travel, but I have still got the problem after replacing the MAF, replacing the TPS, changing all spark plugs. I am now thinking ignition coils. Reason being I have a bit of a rough idle even after changing spark plugs, and I had a similar problem with my Jaguar, which went into "Restrictive Performance" mode, which is limp home mode, and cut the revs over 3,000 revs!
I still can't get a device that reads my OBD11 and havent pulled the codes yet, so I am going to bite the bullet and pay for a local garage to pull the codes, and see where we go from there.
Old 06-08-14, 02:23 PM
JemP
JemP's Avatar
OK, i am revisiting this now. I felt that the car was in restricitve mode, so I checked the coils, when I pull two of the rear coils, there is no difference to the engine revs or anything. That suggests a coil problem. I will be putting two new coils on tomorrow.
Old 06-08-14, 04:53 PM
sktn77a
sktn77a's Avatar
Do yourself a favor and buy a cheap OBDII reader. Check e-bay. You can pick them up for under a tenner.
Old 06-09-14, 04:03 AM
JemP
JemP's Avatar
I have three OBDII readers, all of them work on my other cars, none of them work on the Lexus. So that doesnt help.
I've found out this morning that changing bad coils for known good coils makes no difference. Its like there is no power going to the rear 3 coils, so all of the rear bank seems out of action! Can these things run on 3 cylinders??
Old 06-09-14, 05:40 PM
ATLs460
ATLs460's Avatar
You may have a wiring issue with your OBD port. My Actron scanner will scan literally anything from GM's to BMW's and everything in between.
Old 10-13-14, 02:42 PM
JemP
JemP's Avatar
I finally got to the bottom of this with the help of a very good auto electrician who managed to read the OBD2. I had a coil problem, which a new coil fixed.
More importantly he was able to reset the OBD2 to get out of limp mode, and we are back in business!!
Old 10-13-14, 03:34 PM
sktn77a
sktn77a's Avatar
Bizarre! I have a cheap $10 OBDII code reader and have no problems on my RX300. What code reader did your mechanic use?
danno52
04-08-19 06:11 AM
dpw2552
03-27-17 02:40 PM
12-29-15 11:46 AM
DMPesso
Performance
16
12-10-10 11:55 AM
advsystems
Maintenance
08-31-04 03:14 PM
Quick Reply: Autobox jerking and bucking after fluid change
