Rear sways to left when accelerating
Old 12-04-13, 08:33 AM
HRT
HRT's Avatar
Default Rear sways to left when accelerating
On my 2003 RX300 when I accelerate the rearend pulls to the left (Drivers side) as if I am fish tailing. not sure what is wrong, changed bushing on stabilizer bar, replaced stabalizer bar links. replaced control arms on Passger side last year and in process of replacing Driver's side now. What else could it be wrong?
Old 12-04-13, 08:46 AM
daddykay24
daddykay24's Avatar
I had a car that did this. Would you believe it was the tire pressure?
Old 12-04-13, 10:39 AM
HRT
HRT's Avatar
I thought that might be it, Just purchased brand new tires last week and issue is still going on.
Old 12-04-13, 11:31 AM
salimshah
salimshah's Avatar
AWD or FWD?
Salim
Old 12-05-13, 06:27 AM
HRT
HRT's Avatar
it is an AWD
Old 12-05-13, 08:54 AM
bgross88
bgross88's Avatar
Something else to consider, depending on your tires. I have an Altima (in addition to my Lexus) which needs unidirectional tires. My installer put one on backwards one time...it did the exact same thing you are describing until I took it back.
Just a thought
Old 12-05-13, 09:21 PM
trhs75
trhs75's Avatar
Something with the stability system, maybe? Just a thought.
Old 12-09-13, 06:25 AM
HRT
HRT's Avatar
Replaced Stabilzer bar Bushings, Stabilizer link pins, control arms on both sides. Just running out of things to replace.
Old 12-09-13, 06:46 AM
Z07
Z07's Avatar
Did the alignment shop give you a printout of the final numbers after the four wheel alignment?
Old 12-09-13, 09:55 AM
mshumack
mshumack's Avatar
it is an AWD
I'm not up on the construction of the lexus AWD rear differential, but if it is designed like a conventional rear wheel drive car, you could have a broken or striped-spline on the axle shaft to the wheel. So when you accelerate all the power is going to one rear wheel instead of split between the two. If it where FWD only, the car wouldn't move, but with AWD you may be masking the problem.
Try jacking both rear wheel off the ground and then turn one wheel by hand (chock the front tires and put transmission in neutral). if you turn one wheel the other side should aslo turn (in opposite direction for "open" differential, or in same direction for "limited slip" differential).
Old 12-09-13, 10:31 AM
Z07
Z07's Avatar
2003 AWD is open diff. IIRC 2001 was the last year of the posi.
Old 12-11-13, 05:14 AM
mshumack
mshumack's Avatar
Okay. rethinking this - it is not a broken shaft because if it was (with an open diff) the drive shaft would turn the yoke (pinion and ring gear) but the spider gears would just rotate inside the carrier instead of turning the axle shaft (remember the description of an open differential in the movie My Cousin Vinny - "one wheel spins and the other just sits there".) If you had a broken axle, that would be the shaft turning (one with least resistance) and the other wheel with the good shaft would just sit there.
jimbug
12-24-14 02:19 PM
JAB
03-19-14 08:20 PM
lynhnn
RX - 3rd Gen (2010-2015)
10-29-12 07:35 AM
dtyler5556
12-29-08 06:34 AM
neil0311
06-03-07 06:38 PM
Quick Reply: Rear sways to left when accelerating
