Passengers LOW BEAM not working.
Old 11-11-13, 11:24 AM
M45owner
M45owner's Avatar
Default Passengers LOW BEAM not working.
Am having an issue with the passengers side low beam not working. When the headlights are turned on, the drivers side comes on but not the passengers side. High beams, turn signal, etc work on the passengers side though. If it was a fuse, wouldn't that affect the high beam as well? Any suggestions on what to check for?
Old 11-11-13, 11:30 AM
salimshah
salimshah's Avatar
Maybe the bulb is blown?
You can swap the light bulb from left to right and if the problem travels, you have confirmed the problem.
Other options are to take the bulb out and see or check with ohm-meter.
Salim
Old 11-11-13, 11:31 AM
M45owner
M45owner's Avatar
It's not the bulb, I've already covered all the basics. Swapped with working bulb, checked all fuses, etc. Which is why I am now asking for further suggestions as to what the issue could be.
Old 11-13-13, 08:36 PM
jwyarbroug
jwyarbroug's Avatar
I have the same problem. Turn high beam on and passenger side works, turn to low beam and passenger side headlight doesn't work. I checked the fuses and could not determine any needed to be replaced. Any more suggestion?
Old 11-13-13, 09:07 PM
RX300CE
RX300CE's Avatar
Default headlight relay
https://www.clublexus.com/forums/rx-...002-rx300.html
check out this thread
Old 11-18-13, 01:22 AM
M45owner
M45owner's Avatar
Thanks for the link, although it offers no further help from what ive already tested/tried.
Old 11-18-13, 06:46 AM
salimshah
salimshah's Avatar
Time to pull out the schematics and vom. Sorry no help seems to be coming from CL.
Please post when you find out.
Salim
estone
08-22-17 10:28 PM
SiulMan19
01-12-16 04:19 PM
S-Lex-95
03-07-11 02:58 PM
js0l0
09-13-10 06:13 PM
lostang
04-17-10 09:19 PM
Quick Reply: Passengers LOW BEAM not working.
