2001 RX 300 No Nav CPU Video Input (Nav buttons and wiring in place)
Old 05-04-15, 09:32 AM
  #31
LondonLex
LondonLex's Avatar
Default Reverse Camera
Originally Posted by gazi001
You need adapter to input videos in the screen like Vaistech SL2Vu or try to find any kind which will input videos to the screen.
Hey gazi. The SL2Vu is almost impossible to find here in Europe. Can you please let me know if the SL2Vu adaptor connects to the plugs in the boot or direct to the back of the head unit?
Do you also know what the 4 plugs (2 Blue & 2 White) at the back of the head unit is for. There is an adaptor sold online which has 6 pins like in picture. It is just an adaptor or do you need something more advanced to decode the signal from reverse camera to the head unit?
Attached Thumbnails 2001 RX 300 No Nav CPU Video Input (Nav buttons and wiring in place)-_5712.jpg
Old 05-05-15, 07:29 AM
  #32
gazi001
gazi001's Avatar
It will connect back of the head unit. You could explore this link and find some helpful info: https://www.clublexus.com/forums/rx-...e-project.html
Old 05-05-15, 07:55 AM
  #33
LondonLex
LondonLex's Avatar
Default Reverse camera
(M4 (red line) blue connected with the nav ECU N4 for video input) Can you tell me how many pins there is for this connector please.
Old 05-06-15, 08:44 AM
  #34
gazi001
gazi001's Avatar
The red circle white plug (6 Pins) for add extra video in for the gps nav screen display. It has different shape. You could try to get 6 pin male plug for your female plug which you showed in your previous post for feed video in. It is easy to remove the white plug and if you not find the male plug You may solder the wiring. It is up to you.
Old 05-06-15, 09:30 AM
  #35
LondonLex
LondonLex's Avatar
Wow, thanks gazi. So which means you can connect a feed from a reverse camera to the 6 pin connector & view on head unit screen? Would you happen to know what the 6 pin connectors are for?
So that I can cut the connector off & solder AV connectors to feed the video from reverse camera.
Thanks again.
Old 05-06-15, 10:48 AM
  #36
gazi001
gazi001's Avatar
Thanks again.
For reverse camera I feed from gps ecu in the trunk by Navtool adapter to the front display. For any other videos like dvd, etc. you could feed in the front display may be ( without any adapter). But for the reverse camera when you shift the gear to back up and It will of course not show in the screen rightway. You may get it by manualy. I honestly never try those setup which you thinking. Again you could try.
lomei
CT 200h Model (2011-2017)
01-16-16 11:52 AM
cbuhrman1
09-20-14 02:41 AM
nmtomcat
RX - 3rd Gen (2010-2015)
09-01-13 09:46 AM
benbuilt4u
03-13-12 07:34 AM
studentdoc
10-21-05 10:47 AM
Quick Reply: 2001 RX 300 No Nav CPU Video Input (Nav buttons and wiring in place)
