XADO friction reducer
Old 08-02-13, 07:07 PM
FilPilot
FilPilot's Avatar
Default XADO friction reducer
Been searching the net on XADO 1, reading a lot of testimonials but they look like commercial marketing stuff, not sure if its snake oil.
This is a great forum and I was wondering if anyone has first hand experience using any of these oil additives and could share with us.
(Rdmoon) posted information on XADO in another thread back in April, I was wondering if there are any updates.
Old 08-02-13, 10:36 PM
salimshah
salimshah's Avatar
What problem are you trying to solve?
If you dont have a problem, I would say, stay away from additives.
Salim
Old 08-02-13, 11:22 PM
FilPilot
FilPilot's Avatar
salim
Not so much trying to solve problem but just trying to extend what I have. I have been reading this forum for a while and put to use some of the great advise. Like 6 quart flush for the transmission, synthetic M1 oil, NAPA/Gold 1516 filter.
I would like to see if the transmission shifting can be improved by adding an additive.
I also have a AWD Highlander with noisy drive train (not whining) when at highway speeds. was considering additive in the transfer to see if it quiets it down.
Old 08-03-13, 04:55 AM
Lexmex
Super Moderator
Lexmex's Avatar
Are you talking about using this in the motor oil or transmission fluid?
Old 08-03-13, 06:59 AM
FilPilot
FilPilot's Avatar
Lexmex. The product website says, they make products that work in all areas including engine, transmission, and cooling. I would like to use it were I can get the most benefit.
My 2000 RX 300 just turned 150k, all is well, but would like to keep it that way, preventative.
The link to website http://xado.us/
Old 08-03-13, 07:29 AM
salimshah
salimshah's Avatar
Originally Posted by FilPilot
salim
No! Please no flush. Drain and fill.
Salim
Old 08-03-13, 07:50 PM
FilPilot
FilPilot's Avatar
Salim
I used a siphon pump and refilled...thanks for correcting it Salim
Old 08-05-13, 06:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
I looked at this product many years ago, but concluded it wasn't much different from some of the other oil additives I was using like Restore.
However, for transmission the one additive that I last used going way back to 2007 was the one from Lucas. I ended up having an issue with my tranny related to an accident I had with a piece of road that hit the underside of the the tranny and never got to see the full result, but I sense from the little time I did try it that there may have been a slight improvement in shifting similar to what some of Mexican colleagues with auto transmissions experienced with there's.
For oil, I wouldn't see the harm in trying the XADO, but for transmissions, I would go with a better ATF fluid than use an additive. When I did try the Lucas additive the only Type IV fluid or equivalent I had access to in Mexico was the Toyota Type IV. At the time there was Mobil 1 ATF, but that formulation was no yet Type IV approved.
Old 08-05-13, 07:06 PM
FilPilot
FilPilot's Avatar
Lexmex: very interesting, have been following a youtube repair guy name Scotty Kilmer. As far as I can tell very straight forward mechanic. He also claims to use Lucas transmission additive with great results.
Now the question which one:
1. Automatic Transmission Fluid Conditioner
2. Lucas Transmission Fix
3. Lucas Oil Multi-Vehicle ATF
Old 08-06-13, 06:57 AM
Lexmex
Super Moderator
Lexmex's Avatar
I don't spend much time on youtube, but I have seen the videos of Scott.
My view on this is that if you can find a superior oil, ATF or other fluid, you don't need the additives. I was saddled with the unfortunate situation in Mexico that I really didn't have access to fluids (and importation was expensive, sometimes I had the money/sometimes I didn't).
Personally, I would just move over to a better ATF fluid first. I currently used Redline D4, but Amsoil also has a good ATF along with Royal Purple.
V8TKY
IS F (2008-2014)
32
03-30-14 07:21 AM
Nsteezyy
08-17-13 01:39 PM
A.C Milan
01-07-13 12:05 PM
MrShim78
11-29-12 09:21 AM
Quick Reply: XADO friction reducer
