2002 RX300 idler pulley broke today
After 139k miles the timing belt idler pulley shattered, breaking the upper timing belt cover. Had it towed to the local toyota dealership. They recommended replacing the timing belt and cover, idler pulley, drive belt, crankshaft and camshaft seals, water pump, and doing a coolant flush. They quoted $1275. Is this in line. Everything they wanted to replace seemed reasonable, but I have concerns about the need to flush the coolant
I hope you're not serioius about the 30K mi coolant change. If so, they need to change the name from Long Lift Coolant to EXTRA SHORT Life Coolant! Most LLC's were sold to be good for 100-150K mi. interval and the ELL is even longer. The traditional Prestone of many years ago (really old technology) should have been good for 50K mi. at least. Do you realize that diesel trucks (I know, apples and oranges) NEVER replace the coolant in the life of the truck, even 1,000,000 miles. It doesn't wear out, only depletes the additives. They simply test at intervals and add whatever it shows has depleted in additives.
We will all choose to do different maintenance to our vehicles. Anyway, here's part of the maintenance schedule Lexus provides for the '99 year.
I personally wouldn't do a flush unless for some strange reason the coolant is nasty. The coolant T/L uses is some of the finest available. I changed my DIL's ay 97K mi. for the 1st time and it absolutely looked like it had just been put in. Later when I changed the W/P trying to find a squeal the interior (water chambers) of the engine looked brand new. The was not one single trace of sediment in the coolant I took out. Most flushes have a cleaner in them that can indeed be corrosive, (ask me how I know). I am astonished that the idler shattered. Those parts are also some of the finest I've ever seen. (my whole life spent in automotive work)
BLKGS4
Suspension and Brakes
02-28-06 09:39 PM
