What type of transmission fluid do you use?
Old 04-24-13, 06:53 PM
jolomo
jolomo's Avatar
Default What type of transmission fluid do you use?
Now that my 2001 RX300 AWD is running smoothly with the remanufactured engine, I want to determine the best transmission fluid to prolong the life of the transmission. I can afford another large repair bill.
What type of transmission fluid do you use? Type, brand, synthetic? Fluid change, how ofter?
Old 04-24-13, 06:54 PM
Dlexus81
Dlexus81's Avatar
Synthetic.... Change my oil every 5K miles....
Old 04-25-13, 03:34 AM
hypervish
hypervish's Avatar
Castrol Transmax Import Multi Vehicle - It's a synthetic blend.
Old 04-25-13, 05:47 AM
Lexmex
Super Moderator
Lexmex's Avatar
If you are talking about right now, Redline D4, http://www.redlineoil.com/product.aspx?pid=51&pcid=9 and every 15K miles I take a look at the fluid and generally have changed it at that time, even with the synthetic.
Old 04-25-13, 06:49 AM
lexus114
lexus114's Avatar
This may sound a little strange, but here goes; When I had my 2001 RX300 I noticed that when I used the Toyota brand fluid, I had too much slip-n-slide from first to second gear. When I used the Castrol multi Import vehicle fluid, it shifted MUCH better. However, on my now RX330 this trans works the best on the Toyota brand fluid. Why? I have no idea.
Old 04-25-13, 10:32 AM
lserlohn
lserlohn's Avatar
Valvoline MaxLife ATF is the cheapest synthetic ATF. Only around $25 for 5 qt at Walmart. I used it without problem.
Old 04-26-13, 12:38 AM
Nomjisly
Nomjisly's Avatar
I have read through the tread trying to answer a similar question but i am afraid i have to ask a question instead.
What is the general specification for the best synthetic ATF? i live in an area of Nigeria where it is difficult to get the Toyota branded ATF.
Old 04-26-13, 01:36 AM
salimshah
salimshah's Avatar
There is no such thing as "Best synthetic ATF", just like there is no best engine oil ... or even best food dish ... We all have our favorites.
Lexus specifies Toyota T-IV or better. Any manufacturer can make a claim that their product meets or exceeds Toyota TIV, but make sure you buy good reputable stuff.
Toyota dealership should carry the ATF for their vehicles and even here in USA, I have not seen Toyota T-IV in any auto shops.
Salim
Old 04-26-13, 06:40 AM
Lexmex
Super Moderator
Lexmex's Avatar
Different transmission even with Type IV fluid. I have said this before that a beefed up U140 or something better (more truck like) should have been used on the RX300 and not what is otherwise a Camry transmission. The U151 is an improvement.
Old 04-26-13, 06:42 AM
Lexmex
Super Moderator
Lexmex's Avatar
What brands of transmission fluid do you have there?
There might be something European that might be a Type IV equivalent that is more common there than would be in the Western Hemisphere.
Old 04-26-13, 11:43 AM
lexus114
lexus114's Avatar
Well, it is an all electronic trans and I believe it has the learning adaptable software. However I`m not positive re; that. I really cant complain about the way mine shifts but I do like the way newer Lexus RX models shift. It`s even more crisp. (forgot to mention) My RX300 trans also liked the Wolf`s Head Synthetic fluid too.
Old 10-24-19, 07:51 PM
Highrollr
Highrollr's Avatar
Default What transmission fluid to use 04 Lexus rx330 AWD
I recently bought the castrol high mileage w specifications that list it can be used w vehicles that require IV or higher. ThisIt is my 1st time purchase in transmission fluid this is the 1st vehicle I've had well over a 150K miles can anyone reply that this would be OK to use ?I purchased this product over the synthetic figure in I'm close to 200K miles. This is for 04 Lexus rx330 AWD.
Ty
Old 10-25-19, 08:23 AM
Bill Dowd
Bill Dowd's Avatar
I have been using Max Life on my rebuilt transmission since Dec 2017 and no problems,in the past I used Mobil one trans fluid since 1987. My 2001 RX300 I do a drop and refill every 10,000 to 15,000 miles the trans should go at least 250,000miles.
Running Mobil One I ran 529,000 miles 1986 Toyota Cressida 1991 Lexus LS400 410,000 miles and in many other other cars still on the road. I also put the synthetic trans fluid in my power steering on all my past cars and nothing wore out.
I also use Mobil One 5W30 in the motors changing at 10,000 miles synthetic fluids will make your car go much longer.
Old 10-25-19, 05:16 PM
99RX300PDX
99RX300PDX's Avatar
Toyota, Lexus ATF Type T-IV
Old 10-26-19, 01:21 PM
ricco750
ricco750's Avatar
Ditto! Along with some LubeGard Red.
Quick Reply: What type of transmission fluid do you use?
