RX 300 error codes
Old 04-11-13, 11:32 AM
GaRobert
GaRobert's Avatar
Default RX 300 error codes
I have a 2001 RX 300, and have error codes P0440 and P0442 my Track Offf and VSC light were on. After I checked for the codes I cleared them , All lights and codes have now cleared, but now my A/C and fan are not working at all.. any idea what my be wrong. I did notice a small amount of water under the rear of engine when I backed car out.. Thanks for any help
Old 04-12-13, 07:44 PM
bufferdan
bufferdan's Avatar
Tighten gas cap til it clicks a few times...pull ecu fuse and see what comes back on... Trac and VSC may be wheel speed/abs sensors...could be corroded or stretched/broke wire to one. They are on each wheel hub with a 10mm bolt. Just my guesses
Old 04-13-13, 06:27 AM
carguy07
carguy07's Avatar
The Trac & VSC lights coming on don't necessarily mean that anything is wrong with those systems. Those lights will come on with a CEL automatically. Like a bad air fuel sensor will trigger a code for that sensor but also turn on the Trac & VSC lights. I'm with bufferdan, start with the gas cap, reset and see if it goes away.
Old 04-13-13, 12:01 PM
GaRobert
GaRobert's Avatar
Smile
Thanks guys, tighted the fuel cap and problem went away
thanks again for your help
tonyblu
05-11-18 07:57 AM
bachteb
12-15-13 06:03 PM
Sc5Speed
18
04-13-10 08:42 PM
lowchops
03-14-10 04:48 PM
Quick Reply: RX 300 error codes
