02 Transmission Whine
Hello all, I have an 02 coach edition that has recently developed a whining when you first start it up. I put my ear to the transmission pan one morning and it is coming from there. However, once the car and the tranny warms up it goes way. The car shifts fine and has no problem down shifting when required to do so..
Of course when taken to the dealer, they say to replace the entire transmission at about $5000. The problem is, it's only worth about $7000 so that does not add up to me. Any one else here experience a whinny transmission and what was the end result.
By the way, the car has about 89k on it and it is daily driven. Bought it brand new and we are the original owners. No tranny fluid change was done and the fluid looks and smells normal.
Just so you know, it is worth more than $7k. I'd price it at around $9, considering it's a coach edition with "low" miles. I've seen them go recently for $10k, because the coach edition isn't as easy to find. I just helped my uncle sell an 03' with 114k miles for $8,500 and that was just a standard edition, nothing fancy. lol I almost bought it myself, I still wish I did.
These transmission do all have a very slight whine, but not in idle generally during 1st gear. There's a few threads on here about it, which all say it is normal. However, your's seems to be something different as you say it's making the noise even when in idle.
It doesn't give me a lot of hope when you say it hasn't had a single fluid change done. That transmission has been neglected in my eyes, but may not be seen as neglected by Toyota as they don't recommended a fluid change either. But, it's pretty clear these transmissions need a drain and fill every 15k miles with a stellar fluid, something better than T-IV.
I also have a 2002 Coach Edition. Last winter, mine was also whining when it was very cold & making "other noises" when in second trying to go to third. Seemed to only happen in the cold - and only for the first 5 minutes of driving. Had transmission cooling line corrode this past October - had it repaired & regular transmission service done. Knock on wood, haven't heard any noises this winter (been very cold) & heard no "whining". I would say have your transmission serviced (drain & fill at a minimum) & see what happens. Posted from ClubLexus.com App for Android
Unless you know something I don't the warranty is 4 yrs and 50k.
Hype, the whine at idle is what got my attention. The car is dealer serviced and not one time was a transmission service recommended. I was told that it was a closed system and that it did not need servicing. After conducting a search on here, I am learning different.
What fluid would you guys suggest for a drain and filter replacement?
Some dealerships actually are recommending RX300 owners to change the fluid frequently, such as 15k - 25k mile intervals. Those are the dealerships that look out for their customer.
I wouldn't replace the filter, if it's a screen. Just clean it and put it back. Your filter should be a screen as no one has ever touched it, only paper filters are available for replacement.
I suggest using Castrol Transmax. Import Multi-Vehicle. I've been using it for 60k miles with no issues, and many other CL members are using it as well. A number of folks on BITOG (bob is the oil guy), are also using it as a substitute in other vehicles which spec Toyota Type-IV.
I finally had the fluid and the filter changed. The filter was so dirty that it would not come clean so it was replaced. As a result, I am happy to report that the transmission whine is gone and we are shifting nice and smooth.(Knock on wood.)
I also looked through my records and noticed that prestige lexus had performed this service back in 2010 during one of my services. So it has been done in the past. Just not by my current dealer.
I want to thank you guys for your help and keep your fingers crossed that we don't start slipping.
