2001 RX300 AWD Rear Differential Fluid
Old 02-25-13, 02:46 PM
autodriver
autodriver's Avatar
Default 2001 RX300 AWD Rear Differential Fluid
How much 80W-90 gear oil is needed for drain-and-refill?
Old 02-25-13, 02:59 PM
hypervish
hypervish's Avatar
You will need 1 quart. I recommend Royal Purple 75W-90.
Old 02-25-13, 05:05 PM
salimshah
salimshah's Avatar
Do not attempt to open the drain, without making sure that you can open the filler. There are some sad stories about drained diff with stuck filler.
Salim
Old 04-22-13, 07:40 AM
skysurfing
skysurfing's Avatar
Is it bad to use 75W-90 if 80W-90 is recommended? I called auto parts stores yesterday trying to find Royal purple in 80-90 and one said they had 75w-90 but when I asked if it's ok to use that they said it's better to stick with what the manufacturer recommends. However, several people on here have recommended the 75w-90 so it's ok?
thanks.
Old 04-22-13, 11:23 AM
Lexmex
Super Moderator
Lexmex's Avatar
thanks.
No, there is no issue doing this, I've been using the 75W90 for years and no issues.
Old 04-22-13, 05:20 PM
skysurfing
skysurfing's Avatar
Thanks Lexmex. Hey are you in Tampa? I'm in Clearwater. Do you have any idea about the problem I described in this thread:
https://www.clublexus.com/forums/sho...=1#post7896978
thanks for your write up, it was what motivated me to drop the tranny pan which allowed me to find the large metal chips.
thanks!
Old 04-23-13, 05:46 AM
Lexmex
Super Moderator
Lexmex's Avatar
thanks!
Miami.
The only advice I can suggest on that issue in the other thread is to have you or someone else listen to it an on an empty street as the vehicle goes by to see if you can localize the sound.
Old 11-19-18, 01:27 PM
DanMeyers1
DanMeyers1's Avatar
thanks.
After a great deal of research, I'm using Amsoil Sever Gear 75W-90 in both my front transfer case and rear differential. I don't use Amsoil fluids in any other part of the RX and think it's too expensive - but for the once every 50K miles change, it's well worth it. By the way, I have 145,000 miles on my '02 RX300, use regular dino 5W-30 oil with Bestline engine treatment at every change, and ONLY USE this filter: WIX -- 51348. I can't recommend this filter more highly. My RX runs like new.
Old 11-20-18, 05:25 PM
ukrkoz
ukrkoz's Avatar
Mah Man!^^^^^ That's best gear oil out there... lasts forever.
ToyotaLexus
68
11-21-21 06:15 AM
ownpace
08-25-11 10:06 PM
hugo2648
07-23-07 06:40 AM
autodriver
06-30-04 10:29 PM
whitels
06-01-03 12:23 AM
Quick Reply: 2001 RX300 AWD Rear Differential Fluid
