My 30k Service $250
My 30k Service $250
30k Service
I had the 30k Service done for my 2001 RX SS last Sat at Lexus of Bellevue (WA). I usually get my reg oil changes done at Toyota of Kirkland (where they charge $10 each labor for oil change/tire rotation) but depending on whom I talked to, I was quoted anywhere from $180 to $360 for the 30k service (only the items on the mfr manual and Mobil 1/Oil Filter/Air Filter provided by me). I was quoted $240 for the same at Lexus of Bellevue so I went there – this was my first paid service at any Lexus dealer.
Here is a rundown:
Minor Service [Notes: Its actually Major service for 30k but in the Major service they change transmission fluids etc which I didn’t want and hence the Minor service; I provided 5qts of Mobil 1 oil and Filter and gasket ($9 from Toyota Dealer)]
Change Engine Oil Oil Filter and drain plug gasket
Inspect Enginer Air Filter
Rotate Tires
Inspect Brake System: Front Brakes 6mm Rear Brakes 8mm remaining
Inspect Steering Linkage and Rack * Pinion Assembly
Inspect Ball Joints and Covers
Inspect Drive Shaft Boots
Set 4 Tires to 32PSI Spare=40
Front Tire Depth 4/32 7/32
Rear Tire Depth 6/32
Inspect and Top off all engine compartment fluids
Load test battery, clean terminals and fill
Battery Condition- PASS
Check Int & Ext lights for operation
Check windshield wiper operation, blades and washer fluid
Inspect drivetrain fluids and top off as needed
Cooling system inspection- coolant level good to 34F
Retorque flange bolts
Road Test
Hand wash & Vaccum
$108.53 incl taxes
Flushed Brake Fluid and filled system [No diff in prices for brake fluid (2 qts @ $5 each) from Toyota/Lexus, so let them use their own]
$108.53 incl taxes
Replaced Air Filter [Couldn’t find K&N 32-2045-1 so went with 32-2052; they didn’t complain about it;]
$31.55 incl taxes [Pretty high- I should have done this myself!]
CBEST options were changed at no cost.
Total = $248.61
Was provided with a ES300 (2003) loaner. The Bridgestones on it made a big difference in handling compared to my Integritys. Automatic wipers are great. Must have feature for any future purchase for Seattle weather
Here is a rundown:
Rotate Tires
Road Test
Hand wash & Vaccum
$108.53 incl taxes
$108.53 incl taxes
Total = $248.61
Additional Services?
The following is supposedly the factory recommended service schedule for Lexus in Canada.
http://www.heffnerlexustoyota.com/se...usservice.html
The 48K kilometer service (equivalent to 30K miles) costs about about $250US.
I'm wondering though, if anyone has had their transfer case oil changed, and how much this would generally cost. Its listed under "Additional Service Requirements"...
