Can't read info screen.....
Old 01-25-13, 05:22 PM
Ramblemutt
Ramblemutt's Avatar
Default Can't read info screen.....
....with my sunglasses on. Any suggestions other than the obvious....like not wearing my sungugs? Anything out there that will brighten up the display? Can't really change my glasses as they are magnetically attached and matched to my prescriptions.....$125 a copy.
Old 01-25-13, 05:27 PM
hypervish
hypervish's Avatar
My display is still super bright even after 13 years.
I know it's a dumb question, and I don't mean to insult you but have you turned the brightness up to full on the screen?
Old 01-25-13, 05:39 PM
salimshah
salimshah's Avatar
Polarized glasses can interfere with the visibility of LCD screens.
You can run a controlled experiment in a covered garage, with and without the add on sun-blocker. Or try a non-polarized blockers.
Salim
Old 01-25-13, 06:24 PM
Ramblemutt
Ramblemutt's Avatar
Yes, maxed out.
Salim, I guess you mean the glasses when you refer to sun-blocker. The display is bright under all circumstances other than the glasses.....which are no longer available from the mfg., so cannot get unpolarized versions. I suppose I can just live with it. Thanks anyway.
Old 01-25-13, 06:51 PM
imherenow
imherenow's Avatar
hmm prolly connection loose problem? or might have to replace with new one. Just remove the whole unit if you can to inspect the connections or to check the back side of it.
or just head to scrapyard!!!!..
Old 01-25-13, 08:16 PM
salimshah
salimshah's Avatar
We used to play these games in Physics optics lab ....
I know you cant do this while driving, but try to tilt your head and see if the display becomes brighter.
If it does, then unfortunately the answer we have is what you did not want to hear .. change the glasses. If you must wear polarized glasses, see if they can make you a pair with altered axis.
Salim
Old 01-26-13, 05:01 AM
bob2200
bob2200's Avatar
My issue is with the display visibility when the headlights are on during the day (with sunglasses on). I have the brightness set for night driving, and can't see the display when I have to (by law) turn on the headlights during the day [for driving with the windshield wipers on, or in construction zones in PA]. I know I could crank the brightness up, but too much effort.
I'd be curious if newer models of Lexus have an easier solution to this issue.
Old 01-26-13, 07:36 AM
salimshah
salimshah's Avatar
Not answering your question here, but dont the DRL count for headlights on?
Salim
Old 01-26-13, 08:59 AM
imherenow
imherenow's Avatar
ok m confused on few things..
-->so headlights are on during the day and the screen brightness is set to night driving.??? that doesn't make any sense. you are driving in the day so why would you have it @ night mode. Offcourse you wont see anything.
-->by law turn on headlights? hmm i dont think so by law as long as you have DRL you dont need to turn on main headlights. unless you are living in Sweden
Old 01-26-13, 09:43 AM
imherenow
imherenow's Avatar
Salim
nope DRL is separate from headlights.
Old 01-26-13, 11:04 AM
hypervish
hypervish's Avatar
It's an NJ state law, to have the headlight on if the wipers are on. DRL's do not count, at least not in NJ it may vary.
Old 01-26-13, 11:29 PM
salimshah
salimshah's Avatar
Clarification is lighted lamps, and mot the headlamps. DRL can be counted as headlamps, but not "lighted lamps" as the tail light only comes on when "lighted lamps" are turned on.
Salim
Riva
RC F (2015-present)
06-30-19 09:48 PM
brucemckay
RX - 4th Gen (2016-2022)
11-12-18 04:12 AM
Gammaray8
ES - 6th Gen (2013-2018)
12-08-17 04:52 AM
VJZ
11-21-07 09:20 AM
Quick Reply: Can't read info screen.....
