fuse location for reverse light
Old 12-26-12, 01:24 PM
imherenow
imherenow's Avatar
Default fuse location for reverse light
so i bought these LEDs fro reverse lights (white) but as soon as i inserted into the socket ..booom the other reverse light went out and then both the reverse light do not work. so i started the car and i couldnt turn left or right signals and no reverse lights went on. Also the back up tail lights burned out indicator light came out ( as if some bulb was blown) ..so now i am not sure which fuse is blown ( if any) oooh and also the DRL was also not on. weird.
any ways any ideas guys?..i will check all the fuses again. But i am not sure why inserting that LED lead to the blown fuse..????
Old 12-26-12, 07:33 PM
imherenow
imherenow's Avatar
ah never mind it was just a 7.5amp fuse i believe 34 on the fuse box located on the just below the steering wheel. i just got a bit nervous but i had to remove each fuse to see which one was blown out.
EkimAtled
26
12-07-18 12:11 PM
knyg
03-07-18 05:31 AM
itsivan
03-18-13 02:44 PM
Rick James
01-07-11 07:30 AM
uplusd
12-14-06 08:27 PM
Quick Reply: fuse location for reverse light
