7.5 fuse panel lights not blown
Old 12-19-12, 03:48 PM
drugfree
drugfree's Avatar
Default 7.5 fuse panel lights not blown
1999 rx 300 7.5 fuse not blown but I have no panel lights for radio heating or shifter, fuse was blowing I put a higer amp fuse in it didnt blow but still no lights. Took 15 amp fuse out put 7.5 back in and panel lights still dont come on
Old 12-19-12, 04:04 PM
salimshah
salimshah's Avatar
Have you lost power (+12v) for something else?
Did you smell anything burning?
What changed that initiated the 7.5amp fuse to blow?
Generally going with larger fuse is a last ditch effort.
Salim
Old 12-19-12, 06:52 PM
drugfree
drugfree's Avatar
Hello, I'm having a problem maybe you can help me with I have a 1999 rx 300 my panel lights on the center console radio, tuning, heat, air ect. Plus the shifter lights are not working. Took cig lighter out checked dome light because that was blowing made sure that is not shorting any more that stays on now. However every time I put a new fuse in and the headlights come it it blew the fuse (7.5) . I put a larger fuse in I know your not supposed to but it didnt blow the fuse I put a 15 in and still no panel lights. I pulled that fuse out put a 7.5 back in and it dims the radio light and the dash lights without luminating the panel lights. All the other fuses work as well as everything else. Is that particular fuse port blown? And how do I fix it?
Thanks Rich
kurtismt19
ES - 5th Gen (2007-2012)
05-18-19 06:45 PM
coltking
04-17-15 09:38 AM
greenRX300
12-02-14 09:49 AM
JProdun
Lighting
11-17-13 10:01 AM
Quick Reply: 7.5 fuse panel lights not blown
