Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Sign in using an external account
Register Forgot Password?
VVT Solenoid (OCV) Replacement DIY
Thread Tools Search this Thread Display Modes
Old 03-24-14, 08:38 AM   #76
Roberto1
Trader Score: (0)
Quote:
Originally Posted by salimshah View Post
Always disconnect the battery before working on a car.
A few thing I do are:
Remove the key from ignition [or make sure it is removed]
Wait about a minute after the key is removed [or since the key is removed]
Remove the ground post. [- terminal].
Then work on the RX.
Circuit is formed by providing a loop for the electrons to travel under electromotive (voltage) force. The body (chassis) is like a bare wire that is there to provide the return path. So always disconnect the gnd terminal.
[What are the odds of an accident/short when you do not disconnect? There are fuses etc. Probably low, but why would you like to take the risk].
Salim
Thank you very much guys, my car runs much better now.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Roberto1 is offline   Reply With Quote
Old 04-02-14, 02:11 PM   #77
yourrx300
Trader Score: (0)
Hello Salimsha and BreasLexus, thanks for your excellent DIY procedure. I am able to remove those solenoids. Struggling to remove the screens. I may need a long ratchet more than 12" to reach the back oil screen.
My question: where is the location of the FRONT OCV Oil Screen? You said it is in post #3 green box. I do not think it shows the nut for the oil screen. Could help you help me to locate that.
Thanks for the help
yourrx300 is offline   Reply With Quote
Old 04-03-14, 12:37 PM   #78
salimshah
Trader Score: (0)
Once you remove the bolt, the screen will pull out with it. If not then you will need tweezers to pull it out. Remember the direction the screen comes out (it is conical). If you flip it, it will get crushed and you will loose any filtration it does.
See Post #5. The other is somewhat similar.
Credits need to go Bear and Bear alone.
Salim
salimshah is offline   Reply With Quote
Old 04-03-14, 01:37 PM   #79
yourrx300
Trader Score: (0)
Salim
Thanks SalimShaw, I think I confused you.
My question: where is the location of the FRONT OCV Oil Screen? Which bolt I need to remove to access the screen. Rear one, I can see in the posts but not the front one. I am specifically looking for a bolt to remove to access the screen.
Thanks
Old 04-03-14, 02:25 PM   #80
yourrx300
Trader Score: (0)
Thanks
Please do not bother. I figured out. It is on the right side about an inch below the solenoid.
I will take a picture of the location and post soon.
Thanks
Old 04-03-14, 04:59 PM   #81
salimshah
Trader Score: (0)
Thanks
Its never a bother. Glad you figured it out.
Salim
Old 06-11-14, 10:42 AM   #82
RLwhaler
Trader Score: (0)
Awesome post everyone! I managed to changed out mine 2 months ago.
RLwhaler is offline   Reply With Quote
Old 06-13-14, 02:52 PM   #83
JazzyQuinn
Trader Score: (0)
JazzyQuinn's Avatar
Very helpful post, I will be trying this on my es300 sometime this week.
JazzyQuinn is offline   Reply With Quote
Old 06-16-14, 04:12 AM   #84
Barceloj
Trader Score: (0)
I too had the VSC light go on AND dropped the bolt... UGH! What a pain that was, so many places for it to get lost. I did find out, by looking for the bolt, that removing the air-filter, though a little more work, made getting to the rear solenoid and filter SO much easier.
Barceloj is offline   Reply With Quote
Old 07-25-14, 05:09 AM   #85
CharBaby
Trader Score: (0)
I don't have any CEL codes pertaining to the OCV/VVT-i... Or any CEL's that I haven't been able to cure(O2, A/F Sensors, EVAP).
My '01 RX-300(purchaced new) starts and idles fine, and runs well too BUT, exceleration is lethargic. Take off from a standing start has lost 2 sec from 0-60 and it really feels slow. Once moving, it's fine. I have performed all oil/filter changes(probably waaaaay toooo early) with oils held in high regard(mosty my own syn/blend) and since sludge is a known issue, I didn't want to take any chances. My oil always looks good/clean-ish when doing an OCI. No Oil Useage between OCI's.
I've used PuroClassic & PureONE Filters mostly with an occassional WIX/NAPA or FRAM, STP, DENSO etc.
Syn oils used: PP, QSUD, VSP, Castrol SynTech, HavSyn etc. And for Dino oils, PYB, QSGB, VWB, HavDino. You get the picture
I will attempt to remove the OCV and clean the screens. I won't replace the OCV as I don't have any of the issues that were mentioned in this thread...just slow exceleration. As of July, 2014, we have 92K miles on the clock with me doing all of the maintenance including all fluid changes(ATF, P/S, Coolant, Brake flushes etc.). Again, probably way too soon on all fluids.
0-60
New and for the first couple of years...8.6-8.8 sec
For the past several years...10 sec or longer!!!
Also:
12-18 month ATF Changes(D&F)
3k-5k OCI
3 year coolant Toyota RED
2 year Brake Flushes
2 year P/S D&F
3 year Diff & TC D&F's
So, you can get an idea of this RX's maintenance schedule!
I have cleaned or replaced the IAC, TB, MAF, PCV...Again, NO CEL's pertaining to this system.
I'm not sure if cleaning the screens and replacing the OCV will change things but, I'll give it a try!
Thank you, this has been a GREAT thread!
CharBaby is offline   Reply With Quote
Old 07-26-14, 07:22 AM   #86
CharBaby
Trader Score: (0)
UpDate:
Everything in both of the OCV's were fine. The screens were perfecly clean and the OCV's moved up/down freely. I can 't answer for the electrical portion of these OCV's as I had no power source to activate them. Is there a way to do this?
Old 07-26-14, 10:29 AM   #87
salimshah
Trader Score: (0)
Quote:
Originally Posted by CharBaby View Post
UpDate:
You have the 12v battery.
I used alligator clips and wires to test out mine. Dont remember which pin is + and which is - .
Salim
Old 07-27-14, 11:10 AM   #88
CharBaby
Trader Score: (0)
Yeah, I didn't know if I could connect straight to the 12v battery in the car or I would have tried it. I may try romoving them again as the job wasn't hard itself, though the rear screen/filter was a bit difficult to get out. So, I may give it another try just to check the OCV's movements(not removing the screens) when connected to the 12v.
But keeping in mind, I HAVE NO CEL's!!!
Thanks,
CB
Old 08-17-14, 07:10 AM   #89
nestor32
Trader Score: (0)
Smile
Another happy ending thanks to your DYI post !!! Many thanks for your clear instructions.
Just to confirm, Lexus RX300 I had CEL-P1354 with rough ride with abrupt change in RPMs even if throttle was constant. Some loss of torque as well, engine stopped while negotiating a steep driveway. As soon as I replaced the Front Bank OCV, the enginene was happy and the CEL cleared after a short test drive. I had a bit of an issue removing the valve, most likely because of the rubber o-ring. I gently rotated and pulled at the same time without breaking it. When I applied 12V it started to work, may have just been stuck, but I don't trust it -
Total time: 20 min, cost $130Can and 4 beers
nestor32 is offline   Reply With Quote
Old 08-24-14, 08:59 PM   #90
Mrv8q
Trader Score: (0)
A tip of the hat to BearsLexus for his excellent DIY. On my '99 ES300, the hardest part was finding the solenoids, and the second hardest was disconnecting the solenoid wiring. I wound up removing the solenoid, and then disconnecting; too hard to figure out otherwise. Too congested and hard to access otherwise with my not so big mitts! Happily, my OCV filters were very clean; replaced anyway. The Dorman part numbers as quoted were spot on, thanks to RockAuto!
I can see now what destroys these engines, after 15 + years; HEAT!
Many of the little plastic bits have already perished, or crumble to dust when touched. Good thing I administer to a couple British sports cars... Some hoses split upon removal of the solenoids, glad I had extra hosing available. I will have to revisit the engine bay and order a couple of plastic bits that are no more....
Thanks again for an excellent DIY!
Mrv8q is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
DIY: Changing the battery mikeho IS - Second Generation 87 11-02-14 01:28 PM
vvt solenoid robertog11 ES300 and ES330 1 09-28-14 06:07 PM
OCV Part Numbers shadow2121 RX - First Generation 10 01-24-13 07:10 AM
1999 ES300 OCV Solenoid Part #??? Chester22 ES300 and ES330 5 11-14-12 06:50 AM
Oil Drain Plugs - Dorman EZ-Drain tomv Hybrid Technology 1 07-12-10 07:29 PM
Tags
control, engine lag, lexus, no overdrive, ocv, oil, p1354, price, rx300, solenoid, timing, valve, variable, vvt, vvt solenoid
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
