O2 Sensor Upstream / Downstream
Old 10-25-12, 09:22 AM
blaster30
blaster30's Avatar
Default O2 Sensor Upstream / Downstream
Whats the difference?
I am getting a code P1135 and the guy at AutoZone said it was the downstream sensor. I think it is the upstream one. I am planning on replacing both, want to make sure I understand and order the correct DENSO part.
Thanks,!
Old 10-25-12, 09:56 AM
Baetke
Baetke's Avatar
P1135 is a Bank 1 Sensor 1 heater circuit malfunction. Sensor 1 is the pre-cat A/F sensor not the O2 sensor after the cat. You should be able to check this with your volt/ohm meter. Check for heater resistance. If the heater is burned out, you will get an open circuit. If you get a low resistance (a few ohms) it is ok. Then check to see if its getting power.
SICK350
ES - 5th Gen (2007-2012)
03-11-14 05:20 PM
natman
Maintenance
12-26-13 03:50 PM
mrchacon
06-26-09 05:22 PM
johnslee
01-11-09 02:03 PM
swat1727
10-01-08 11:50 AM
Quick Reply: O2 Sensor Upstream / Downstream
