RX300 Heat Shield help!
Old 10-23-12, 07:14 PM
dbui
dbui's Avatar
Default RX300 Heat Shield help!
rx300 2001 I am looking for used or savage heat shield the one in the back of the car which protect the gas tank. Called Stealer quote $400 for the aluminum heat shield part. I been calling about 8 places in VA and MD savage and Junk yard but no luck. If you know where I can find one please help! Thank you!
My just got damage today on the highway don't know what I hit but heard the big bang under the car, when I got to work take a closer look saw the piece of aluminum all bent out of shape, call up the dealer to identify the part, it was a back heat shield protect the gas tank from the muffler heat.
Old 10-23-12, 07:33 PM
salimshah
salimshah's Avatar
How about reshaping the piece?
It does not need to be perfect.
Salim
Old 10-23-12, 08:10 PM
thomas1
thomas1's Avatar
agreed that is what I would do....
Old 10-24-12, 04:39 AM
dbui
dbui's Avatar
yeh I think that the route I have to go. How hard it's to take it off the car anyone did it? it wraps around the drive shaft, I don't need to take off the drive shaft do I ?
Old 10-24-12, 08:25 AM
salimshah
salimshah's Avatar
By intuition, during normal assembly process shield goes on first and the shaft and exhaust.
Since yours is damaged, you will have to make the call. As you will be beating the sheet back in shape, you would like easy access to test it out again and again. So removing both may be the best way to do the fix.
You can try to bend the sheet ... more or less like a street repair. I would get large washers (fender washers) to bridge over ripped holes.
If you do remove the drive-shaft... remember to mark each connection, as the shaft MUST be attached the same way that you remove (to get rotational balance. If you dont then you will get a rumble and it will take many attempts to fix it). I dont have AWD, but have worked on rear wheel drive vehicles and they use a support. The support has side to side adjustment and if you have to unbolt it, remember to mark its position. Bright colored spray paint is good to establish exact mount point. Safety glasses are a must working underneath.
Salim
Old 10-24-12, 09:18 AM
dbui
dbui's Avatar
Many Thanks Salim great info!
Old 11-24-12, 07:12 PM
RoX300
RoX300's Avatar
Default Heated O2 Sensor Protection Shield available new for about $ 13
I think you're dealer was trying to rip you off with that quote for $ 400. A new replacement Heated Oxygen Sensor Protector is available for about $ 13: http://www.lexussouthatlantaparts.co...943748010.html
shinbo
GX - 1st Gen (2004-2009)
13
03-30-15 09:11 AM
00&02rx300
11-03-10 10:55 AM
kevin95195
08-01-08 02:16 PM
bored7one4
10-03-06 08:10 AM
lkhodab
31
11-03-03 04:13 PM
Quick Reply: RX300 Heat Shield help!
