Heat Servo won't move
Old 09-27-12, 02:13 PM
CJspoppie
CJspoppie's Avatar
Angry Heat Servo won't move
Have read tons of these posts and have my glove box all apart after having cold air blowing. Traced it down to Hot/cold servo (may not be correct). Tried to clean and nothing. When I did hook it up to test, the arm only went to one spot regardless of heat control position. Bit the bullet and ordered new airmix servo from dealer and installed, connected harness and "NOTHING".
Saw a post about removing the ECU-B fuse so I did and went to try heat and it moved like it should. I was very happy. Went inside for about 1 hour, came out to put back together and Nothing!!!!
Yes I tried fuse again!!
The servo doesn't seem to be getting correct signal or NO signal...
Any ideas?? What next?
Old 09-27-12, 05:00 PM
salimshah
salimshah's Avatar
Just a thought ..
Try warming the engine a bit. The fan does not kick in till the coolant gets a bit warm, maybe the the servo also waits.
Salim
Old 09-28-12, 07:44 AM
CJspoppie
CJspoppie's Avatar
Default Tried waiting until warm....still nothing
Does anyone know how to test at the servo itself to see if it's getting a signal/voltage etc. I am assuming that if I have a brand new servo and it still isnt working, then its not getting a signal..
Old 09-28-12, 08:19 AM
mroxas
mroxas's Avatar
may I know the OEM part Number for the air mixed servo ?
thanks,
Mike
Old 09-28-12, 11:20 AM
hypervish
hypervish's Avatar
thanks,
Mike
8710648020
You can get it for $143.07 from Sewell with the CL discount.
k954triniz
IS - 1st Gen (2001-2005)
01-07-12 09:16 AM
UNOHOO
09-05-11 06:54 AM
Drrawdog1
SC- 1st Gen (1992-2000)
07-12-06 10:50 AM
Lexusnyc
05-14-03 07:31 PM
Quick Reply: Heat Servo won't move
