Advice needed - can I ignore this issue?
Old 08-29-12, 03:02 PM
Stemmer
Stemmer's Avatar
Default Advice needed - can I ignore this issue?
Got a flat tire, put on the spare and took it to Mr. Tire. They showed me the gash and it could not be fixed. In putting on the new tire they showed me how the tires were not wearing evenly and recommended a 4-wheel alignment. I knew I passed on it last time so I gave it the OK. After putting it on the alignment machine, I was told an alignment can't be done as I need front and rear inner and outer tie rods which would run $1,100. I passed and they then tried using a blowtorch to apparently do something to be able to perform the alignment. Ultimately they could not do the alignment. My car is actually pulling just a little to the right - I did not notice it before but I'm sure it was there.
The question is can I ignore this issue? It will pull a little and may worsen and the tires are not wearing perfectly. But I don't want to drop $1,100 on this issue. Any other options?
Old 08-29-12, 03:19 PM
bob2200
bob2200's Avatar
There are more options than (1) pay $1,100 to Mr. Tire or (2) do nothing. I would suggest you take the car to a mechanic who knows what they are doing regarding auto suspension and has the state-of-the-art alignment equipment. There are plenty in Maryland. If you can't get a recommendation, take it to a Lexus dealer. You could ask on the Northeast Lexus forum here at ClubLexus for recommendations. Then, when you get a 2nd opinion, report back to this forum. Those are my suggestions.
Old 08-29-12, 03:27 PM
Stemmer
Stemmer's Avatar
Those are good suggestions, thanks. I have a good indy but I'm not sure if he has an alignment machine. If he does I will have him look at it; I suppose I could have him check it out even if he doesn't. I could also use my dealer. They do good work but it's so pricey every time I bring it there. Thanks though. I will look into other mechanics with alignment expertise.
Old 08-29-12, 03:32 PM
PaulDaisy
PaulDaisy's Avatar
Where I live, Big-O Tires have Hunter alignment machines, which are very good. Big-O checks the alignment for free and if they can't align they will tell what the problem is. This is what I have always done. They in fact have recommended me a part number to buy elsewhere that would allow them to align my other car, which worked perfectly.
Old 08-29-12, 07:18 PM
trhs75
trhs75's Avatar
If your indy doesn't have an alignment machine, I'm sure he'll know a reputable shop to use.
lexus114
25
03-30-15 08:25 AM
theoryguy3
08-11-14 01:55 PM
kurency
Suspension and Brakes
02-19-12 01:45 PM
thomastan
04-24-09 08:59 AM
lexusk8
Wheels, Tires & Brakes Forum
04-15-04 09:55 AM
Quick Reply: Advice needed - can I ignore this issue?
