Rear main seal leak- auto rx?
Old 07-31-12, 09:04 PM
bcg02
bcg02's Avatar
Default Rear main seal leak- auto rx?
So, my 03 with 155k on it finally had an issue. Noticed about half an ounce of oil on the floor, leaking from the point where the engine and trans meet.Further research suggests this is almost certainly the rms.
In an effort to not spend 1500 on the repair,i have been looking into alternatives. Lots of good things on doing two bottles of auto rx and the sludge treatment instructions.
My oil has always been extremely clean, and no varnish or consumption ever.
Should i do two bottles or one? Any other advice on this product? Any experience with it?
Old 08-01-12, 12:24 AM
gazi001
gazi001's Avatar
Auto-RX is good. Try atleast 2 bottles.
Old 08-01-12, 04:27 AM
salimshah
salimshah's Avatar
Have you consistently used the same brand/type and weight of oil?
Salim
Old 08-01-12, 04:49 AM
bcg02
bcg02's Avatar
Castrol gtx, 5w 30
Old 08-01-12, 06:04 AM
hypervish
hypervish's Avatar
Yes, give Auto-RX a shot. Usually it works!
I thought I had a rear main seal leak a few years ago, but it magically disappeared within' a week. It only showed up when I switched to a newer thicker oil, which I never used again due to it starting what I thought was a leak. Luckily, the leak hasn't returned since it made it's premiere launch a few years ago
Old 08-06-12, 08:38 PM
bcg02
bcg02's Avatar
Changed the oil and added one bottle. I plan on driving about 1500 miles, then changing the oil filter only. Then doing a full oil change 1500 miles after that. I will repeat as necessary. Really hoping this fixes my rear main seal leak!!
Old 08-07-12, 12:56 AM
code58
code58's Avatar
Please share your experience with Auto RX, good or bad. Helps the next guy who is in the same spot to know what decision to make.
Old 08-07-12, 08:46 AM
RX300CE
RX300CE's Avatar
Auto RX works for my car I had rear main seal leak, I used only 1 bottle after 2K miles it's totally stop leak, now I am using Castrol GTX 10W-30 for summer and 5W-30 for winter, I am not so sure mobil 1 synthetic caused a leak so I stop using it.
Old 08-07-12, 09:47 AM
hypervish
hypervish's Avatar
Once you use Auto-RX, I think they suggest that you stick with a conventional oil.
Old 08-08-12, 10:29 AM
lexus114
lexus114's Avatar
GTX = Good Stuff!
Old 09-24-12, 07:40 PM
dirkdiggle
dirkdiggle's Avatar
Anyone ever try using 2 bottles of Auto-RX at one time?
Old 09-24-12, 09:38 PM
salimshah
salimshah's Avatar
You ask because the manufacturers recommendation did not work, or you are hoping for a quicker cure? Your answer would help members to give you better advice.
Personally I am not a fan of additives due to possible side affects, but lot of folks speak highly of this product.
I would suggest a repeat treatment instead of double dose.
Salim
Old 09-24-12, 10:25 PM
dirkdiggle
dirkdiggle's Avatar
Have not tried it yet myself but have a RMS leak and was wondering if anyone has tried a double dose of this stuff with good results?
Old 02-04-13, 08:54 PM
oyerbl
oyerbl's Avatar
Bcg02,
Any update on your rear main?
Old 02-05-13, 12:28 AM
dirkdiggle
dirkdiggle's Avatar
One Bottle Fixed my RMS Leak after 2k miles.
Quick Reply: Rear main seal leak- auto rx?
