Air intake box gaping open
Old 06-18-12, 09:05 AM
soonerck
soonerck's Avatar
Default Air intake box gaping open
I just bought this 99 RX300 last week and have been doing some routine maintenance such as oil change, Lexmex MAF and throttle body clean out (thanks LexMex) as well as changing the airfilter. When I put the breather box back on I noticed that it wasn't "seating". The Left side doesn't grab. Does anyone have a pic so that I can see what I'm missing or what might be broken? Everything looks right but I think I might be missing clamps or something. Thanks
Old 06-18-12, 10:27 AM
salimshah
salimshah's Avatar
Hard to tell if the plastic is broken off.
The cover has the "L" ( _| ) piece which should go under the base side ways U ("c. Unhook the clips and try to slide the top cover under the U.
It should look lik
c _| <= best picture I can draw. I hope you get the idea.
Salim
Old 06-18-12, 11:07 AM
soonerck
soonerck's Avatar
Nothing appears broken, butg no matter how hard i press it won't stay once i latch it.
Old 06-18-12, 11:10 AM
lexus114
lexus114's Avatar
Is it in the groove correctly?
Old 06-18-12, 11:23 AM
CANDYAPPLE
CANDYAPPLE's Avatar
Maybe you have the filter in wrong or not seated properly.
Old 06-18-12, 11:38 AM
hypervish
hypervish's Avatar
It should look lik
Salim
Look at the 4th step, and look at second 14. You will see what Salim is talking about.
http://www.carcarekiosk.com/video/20...engine/replace
Old 06-18-12, 12:04 PM
soonerck
soonerck's Avatar
Okay, I checked again and indeed the bottom tabs are broken. If you look in the picture you can see the corners of the lower "grab" tabs are broken. New box? Bone yard? or is there a way to clamp these areas down? Short self tapping sheet metal screws?
Old 06-18-12, 12:05 PM
salimshah
salimshah's Avatar
Take the filter out to test.
Finesse is required and not so much force. The red pointers you marked are sort of an hinge as you drop the cover down for the clasps to catch. The passenger side of the cover does not have the clips for that very reason.
Once you do the dry run (without filter), you can try with the filter. This time you will need a slight pressure to squeeze the rubber around the edge of the filter (which forms a seal).
It is a bit irritating but simple enough.
Salim
Old 06-18-12, 12:08 PM
salimshah
salimshah's Avatar
You can take zip-ties and or short bungee cords till you find the right box.
other alternative is to go for a air-intake mod.
Salim
Old 06-19-12, 07:54 AM
soonerck
soonerck's Avatar
A screw through each tab did the trick. The filter fit was fine. Now about that 0330 code... Crap!
Old 06-20-12, 06:12 AM
CANDYAPPLE
CANDYAPPLE's Avatar
code 0330 is your knock sensor code. sometimes this is triggered by the 02 sensors going bad, or it just might be the knock sensor itself. have them both tested first before replacing anything.
Old 06-20-12, 08:14 PM
soonerck
soonerck's Avatar
I'm replacing both. Spark plugs too while I'm at it.
isfvss
IS F (2008-2014)
08-28-16 01:09 AM
volson
06-20-15 01:15 PM
IS350atWOT
Hybrid Technology
03-08-13 06:38 AM
Inabj2
Performance & Maintenance
02-03-06 02:37 AM
pilip99
10-18-04 01:25 PM
Quick Reply: Air intake box gaping open
