5w-30 ---> 0w-30
Old 04-08-12, 11:17 PM
autodriver
autodriver's Avatar
Default 5w-30 ---> 0w-30
What are the advantages and disadvantages of using 0W-30 motor oil instead of 5W-30 motor oil to your 1st generation RX300?
Old 04-09-12, 03:59 AM
carguy07
carguy07's Avatar
It flows better when it's cold.
Old 04-09-12, 05:22 AM
hypervish
hypervish's Avatar
Pretty much what carguy07 said. And...
Once the oil reaches operating temperature, it will be the same viscosity/weight as the 5W-30.
Old 04-09-12, 09:01 AM
01rxwhite
01rxwhite's Avatar
I agree. I just changed my oil this weekend with Mobil 1 0-30w, synthetic. I had tried it before in the winter, but it should be good year round. The idea of the 0w viscosity is it flows better when cold and supposedly the engine is better lubricated on cold starts. Also, the engine supposedly warms up quicker to operating temp. Again, SUPPOSEDLY, it is more fuel efficient for those reason. Having used this oil, I haven't really noticed any fuel savings. The only advantage I've noticed is my RX seems to run and shift a little smoother on cold winter mornings when temps are around 20-40 degrees. It doesn't get much colder here though. There are no disadvantages that I can see as long as the price is the same.
Old 04-09-12, 09:24 AM
NyCrAzY
NyCrAzY's Avatar
Agree with the top three comments. Me myself also switched over to 0w-30 Mobil 1 and noticed better performance.
Next oil change, I will try the oil our loyal member, Lexmex use ... which is the Castrol GTX 0w-30 I believe. A bit expensive tho because its sold per quart oppose to the full 5 quart jug.
Old 04-09-12, 09:31 AM
Marklouis
Marklouis's Avatar
Same here - I switched mine to Mobile 1 0-30 in my LS-430 last oil change and the difference was noticeable, especially on gas mileage, it went from 26 MPG highway to 29.
Old 04-09-12, 09:35 AM
Marklouis
Marklouis's Avatar
To add I also blew out my pollen filled air filter during the oil change, so that contributed to gas mileage as well
Old 04-09-12, 10:13 AM
hypervish
hypervish's Avatar
He uses German Castrol Syntec 0W-30 (European Formula).
Old 04-09-12, 03:26 PM
NyCrAzY
NyCrAzY's Avatar
My mistake, thanks for correcting me.
Old 04-09-12, 04:39 PM
hypervish
hypervish's Avatar
You're welcome.
Let us know how you like that oil compared to what you are running now.
Old 04-10-12, 07:18 AM
lexus114
lexus114's Avatar
That German Castrol is a thick 30 weight. You will have much better performance on the Mobil 0W-30.
aboss3
04-24-18 10:59 PM
Toto8
06-14-14 05:43 PM
lexus114
01-17-09 10:40 AM
ldc
06-06-07 07:32 PM
kreativ
Maintenance
17
04-05-02 08:47 PM
Quick Reply: 5w-30 ---> 0w-30
