Rear disc pads to thick.
Old 03-18-12, 02:41 PM
Momscar
Momscar's Avatar
Default Rear disc pads to thick.
Got pads at Kragen, fronts went in no problem. Rears are so thick (wear material, they will not fit over the rotors (the gap is not wide enough). The pistons are all the way in. The side opposite the piston is just a fixed (non moving) part of the caliper.
So I go back to Kragen and they have 2 other qualities of pads. There the same thickness.
What am I missing?
I could probably get them to fit if I remove the stainless backing plates, but that doesn't sound like a good idea.
Old 03-18-12, 06:31 PM
RX300CE
RX300CE's Avatar
maybe you got a wrong parts, 2WD & 4WD are not the same pads
Old 03-18-12, 06:45 PM
carguy07
carguy07's Avatar
The pads are the same for FWD & AWD, but the rotors are not. Did you replace the rotors?
Old 03-18-12, 09:39 PM
RX300CE
RX300CE's Avatar
Yes, you're correct, rotors are not the same, brake pads are the same
Old 03-19-12, 08:35 PM
Momscar
Momscar's Avatar
No rotors were not replaced. They could of been last brake job. But pads would have been replaced at that time also.
I removed the whole caliper assembly and was able to slide pads out and slide new pads in.
Would not fit over rotor.
Returned pads and order new Lexus pads and will try them next weekend and take pictures if they don't fit.
Old 03-20-12, 07:04 PM
carguy07
carguy07's Avatar
I would guess that your slides are seized up. Give them a smack with a hammer.
See post # 17 https://www.clublexus.com/forums/rx-...ust-boots.html
Old 03-21-12, 04:26 AM
artbuc
artbuc's Avatar
I would guess that your slided are seized up. Give them a smack with a hammer.
Then remove, clean and re-lube. It is a challenge to keep these pins lubed because (I think) the fit is so tight. I learned that the slide pins needed service well before I needed new pads.
Old 03-21-12, 06:02 PM
carguy07
carguy07's Avatar
Sorry, meant slides not "slided".
mikek753
06-27-19 10:33 AM
kuuqi
Suspension and Brakes
06-11-12 08:22 PM
LXOGOOD
16
04-24-08 10:03 PM
gshb
11-19-07 10:56 AM
LexLS
Maintenance
10-23-03 12:46 PM
Quick Reply: Rear disc pads to thick.
