99 RX audio upgrade log
Old 02-26-12, 08:14 PM
RXdriver11
RXdriver11's Avatar
So this is where the polyester I had laying around for the radio came from. The structure starting to take shape
Old 02-26-12, 08:18 PM
RXdriver11
RXdriver11's Avatar
Both sides finished with polyester and ready for some resin
Old 02-26-12, 08:21 PM
RXdriver11
RXdriver11's Avatar
some dry time
and a little test fit..
Old 02-26-12, 08:24 PM
RXdriver11
RXdriver11's Avatar
The pictures dont really show it but there was a lot of sanding that went into these..
Old 02-26-12, 08:29 PM
RXdriver11
RXdriver11's Avatar
More coming ive got a hand cramp, and have got to rearrange a few pictures..
Old 02-27-12, 05:37 PM
RXdriver11
RXdriver11's Avatar
More work..
Old 02-27-12, 05:39 PM
RXdriver11
RXdriver11's Avatar
This is a sanding and test fit of the speaker with a damaged one i had laying around. Its starting to take shape.
Old 02-27-12, 05:42 PM
RXdriver11
RXdriver11's Avatar
This is after a lot of primer and sanding..
Old 02-27-12, 05:45 PM
RXdriver11
RXdriver11's Avatar
This is the final coat with some primer filler before paint..
Old 02-27-12, 05:50 PM
RXdriver11
RXdriver11's Avatar
Laying down some paint
and after the paint was a few coats of a clear..
Old 02-27-12, 05:59 PM
RXdriver11
RXdriver11's Avatar
And finally the finished product..
here are the speakers that are in now..
Old 02-27-12, 06:05 PM
RXdriver11
RXdriver11's Avatar
Now this is a pure audio install but I do have a Lexus and want to keep it clean and classy looking. Here are a few shots of the equipment going in..
and a better shot of the sub woofer. Its a 15" Ascendant Audio SMD sitting next to a 10". If you are familiar with car audio then you have an idea what the SMD is..
Old 02-27-12, 06:07 PM
RXdriver11
RXdriver11's Avatar
These are going in as well..
Old 02-29-12, 11:49 AM
nnym4
nnym4's Avatar
Really nice work!! I saw a couple of threads were people said they replaced the cd changer with a head unit, which is still a possibility for me. What I had in mind for my RX was getting a CarPC or a double din touch screen that can play videos through a rear usb port. My plan was to attach a external HD through the back of the head unit and have it sit where the CD changer currently is.
I have also seen someone put a single din touch screen monitor IN the glove compartment, so when you open the glove compartment you can have the screen come out, but you would be able to close it and make everything still look stock. Only thing I dont like about that is that it would be far from the drivers seat and could be a hassle. Like I had said in the other thread, I am still not sure as of what I am going to do, but I am still gathering ideas of what I could do. Still, really nice work with the tweeters and glove box! I will definitely subscribe to this thread to see if you add anything else!
P.S. With the glove compartment closed, how well does the RF remote work and how were you planning on seeing what song you had on? Were you just going to drive with the glove compartment down or find a way to connect it to the monitor on the dash?
Old 02-29-12, 07:35 PM
RXdriver11
RXdriver11's Avatar
Thanks. If I were you I wouldn't rule out the glove box. It will let you bypass the stock radio and still keep a hidden and clean look. With the glove box down the remote works perfect.. but I got sick of having it down all the time. So I added the wired remote you see below. It controls the radio functions from outside and is close to reach from the drivers seat.
Quick Reply: 99 RX audio upgrade log
