PCV Valve R&R whoops...
Old 12-16-11, 07:02 PM
C-Stone
C-Stone's Avatar
Default PCV Valve R&R whoops...
Went to change out the PCV valve on the '99 RX300. The plastic was very brittle and immediate broke off as I tried to pull it out of the grommet. Then, as I went to pull the grommet out with the plastic PCV nipple still stuck in it... it dropped into the valve cover hole.
I was able to grab the part a couple of times with mechanical fingers. But it dropped back in both times. The last time I dropped it... it totally disappeared. I had visions of having to take a lot of the top of the engine apart.
However... after taking a break by hanging some Christmas ornaments my dear wife wanted hung, my future son-in-law (21) came over. He suggested trying to stick a piece of tubing in the end of a vacuum cleaner and sucking the part back up to retrieve it. This worked like a champ. The grommet came right up and stuck to the end of the tubing, but up against the top of the valve cover hole.
From there I poked it with a small screwdriver, and slowly pulled the plastic nipple through the grommet first. Then sucked the rubber grommet up to the top of the hole and retrieved it with another screwdriver. Whew!
The retrieved grommet, PCV nipple, and the vacuum hose:
Old 12-16-11, 09:13 PM
salimshah
salimshah's Avatar
Did your future son-in-law read CL? This has been discussed. In any case he had the right idea.
Salim
Old 12-17-11, 05:16 AM
hypervish
hypervish's Avatar
Glad to hear you didn't have to pull the rear valve cover, cause that would have been a pain in the ****.
Old 12-17-11, 01:26 PM
C-Stone
C-Stone's Avatar
Salim
He's a budding, thinking mechanic and loves cars. He has an '05 Mini Cooper S that he's done a number of mods to... as well as Auto Crossed. Of course they have their own forums.
Yes! Thanks.
Old 12-17-11, 06:09 PM
Lexmex
Super Moderator
Lexmex's Avatar
That's cheating...I wanted to see the motor torn apart.
flux702
Performance & Maintenance
04-29-20 08:08 PM
trhs75
05-17-13 09:07 PM
lexo98
07-05-12 03:49 PM
decypher
08-22-11 09:30 PM
phil128605
02-09-10 08:11 PM
Quick Reply: PCV Valve R&R whoops...
