Power Steering Pump??
Old 12-22-11, 11:02 AM
hypervish
hypervish's Avatar
Originally Posted by salimshah
Here us an after thought ...
Mark the PS pump fluid level. Keep an eye and if it drops, you have leak
Oh well, maybe it will help some one else.
Salim
Yeah, I'll keep an eye on it. The level hasn't been going down. So, hopefully it's fine. I saw the leak myself coming from the rear valve cover so I'm sure that's the leak. I was surprised.. LOL
I'll try and snap pictures under the valve covers to show you guys how clean it us under there. Well at least let's hope it's clean. I'm sure it will be though, since I change the oil every 3-5k miles always with a synthetic.
Old 12-23-11, 09:09 PM
JohnLX300
JohnLX300's Avatar
Originally Posted by artbuc
Thanks John. Is that a seal that gets pressed onto the shaft? What type of puller did you use to remove/replace the drive pulley?
As I recall, no seals get pressed onto the shaft. I don't remember what puller I used. I went to autozone and borrowed one with their loan a tool program. I told them that I needed a pullet for my power steering pump, and they gave me a puller and it worked perfect.
Old 04-02-13, 07:52 PM
gazi001
gazi001's Avatar
Default Power steering pump leaks !!!!
Originally Posted by hypervish
Just an update for you guys still following the thread.
It's actually not the power steering leaking, I was wrong. LOL
The rear valve cover is leaking. So, I'm going to get the rear valve gasket, front valve cover gasket and oil pan gasket replaced. I'm also getting the Throttle Body and IACV cleaned for free since they have to remove it anyways.
I wish I hadn't already gotten the spark plugs done over the summer and paid all of that labor. Oh, well...
Hyper, I have similiar problems like yours. My rear valve cover leaks little. But the power steering pump also looks leak. I wants to replace both valve cover gaskets and fix the P.S. pump leaks with the power steering pump seal kit (Gates from Rock Auto.Com). Did you already replaced the valve cover gaskets. Here is pictures of my P.S. pump leaks. I was confused with leaks from P.S. pump or valve cover gaskets! The power steering fluid level was little less in max. I will check the level for few days if it get down more and more. Steering don't make any noises when I turn or no problems.
Attached Thumbnails Power Steering Pump??-power-steering-pump.jpg   Power Steering Pump??-power-steering-pump-leaks.jpg
Old 04-03-13, 03:37 AM
hypervish
hypervish's Avatar
Yeah, I've replaced both valve cover gaskets. It was in fact the valve cover gasket leaking. I think it's the same issue with yours. My power steering pump looked the same way, but it's now dry. I didn't touch the pump at all, just the valve cover gaskets.
Old 04-03-13, 09:50 AM
gazi001
gazi001's Avatar
Thanks Hyper.
Old 04-03-13, 11:30 AM
hypervish
hypervish's Avatar
Originally Posted by gazi001
Thanks Hyper.
You're welcome!
rkt10
20
12-19-21 02:44 PM
amblyn
12-03-11 08:30 PM
edinburger
03-13-11 03:31 PM
g35c
05-30-10 09:35 PM
lemmerdeur
09-06-09 08:41 PM
Quick Reply: Power Steering Pump??
