Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Sign in using an external account
Register Forgot Password?
Cracked key shell casing - help needed
Thread Tools Search this Thread Display Modes
Old 02-08-14, 10:15 AM   #31
donberto
Trader Score: (0)
Thumbs up New Lexus 2003 LS430 key shell
2/8/2014
Today I received two new shells with the key cut from Remote4less. I sent them the 5 digit code from my car and they cut the blade. The cuts were included in the $24. It works for me.
Donberto
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
donberto is offline   Reply With Quote
Old 02-10-14, 11:37 AM   #32
JWRussell
Trader Score: (0)
Quote:
Originally Posted by damon View Post
JW Russell,
Your search lead me to 1010keys out of San Fran. Is this correct?
That is the one, they sent it to me right away no problems!!
JWRussell is offline   Reply With Quote
Old 02-10-14, 08:41 PM   #33
trhs75
Trader Score: (0)
I had excellent luck with them, also!
trhs75 is offline   Reply With Quote
Old 02-10-14, 09:09 PM   #34
tman1352
Trader Score: (0)
Default Go to Ebay for key shell.
I had the same problem and got a key shell with a blank key for about $4 on Ebay. It is easy to switch over the interior piece, no programming is required. You have to get the key blank cut. If anyone knows where I can get that done in Coral Springs/Tamarac Florida I would appreciate the info. All the best and let me know how you made out.
tman1352 is offline   Reply With Quote
Old 02-11-14, 12:18 AM   #35
salimshah
Trader Score: (0)
Quote:
Call your local dealer parts, they might cut the key for you. They may refuse and insist that you buy the key blank from them. You can try local locksmiths too.
Salim
salimshah is offline   Reply With Quote
Old 02-11-14, 05:58 AM   #36
hypervish
Trader Score: (0)
hypervish's Avatar
lexusvishal
If you need to call locksmiths, make sure they can cut sidewinder keys. If they can't, don't bother wasting your time going there as they won't be able to cut it.
__________________
hypervish is offline   Reply With Quote
Old 02-17-14, 06:55 PM   #37
tman1352
Trader Score: (0)
Thanks to all for your responses. I have already transferred the electronics part and will visit a dealer to get it cut, now that I have a ball park for the cost, when I have the time. It is my spare key.
Old 02-20-14, 11:49 AM   #38
davidyal
Trader Score: (0)
Default Replacing keys
So, I just broke my second (original) key shell. Plastic snapped right above the metal shaft.
Is there a consensus on the best way to get a new key for an RX300? I was going to go to the dealer and buy a blank key ($10), have them cut it ($25), and then witch out the electronics myself.
I've seen that you can order already cut keys. Has anyone tried that? Is it less expensive?
David
davidyal is offline   Reply With Quote
Old 02-20-14, 06:44 PM   #39
tman1352
Trader Score: (0)
Default Key case Rx300
I bought a key case with blank key on Ebay for $3.95 including shipping. The electronics are very easy to transfer and don't require reprogramming. An instruction leaflet was inside but I did not need it. This is a spare key so I have not had a chance to cut it yet. $10. from the dealer is ok though and you could get it all done at the same time. Hope it all works out.
Old 03-11-14, 04:41 PM   #40
Eternity Key
Former Sponsor
Trader Score: (0)
https://www.facebook.com/EternityKey
There is FINALLY a better replacement key that provides a lifetime warranty - it's called the Eternity Key. It's cheaper than Lexus OEM products and stronger than anything on the market. Get info at www.eternitykey.com- check under ORDER to see where you can purchase it - or ask your dealer! You will never have to buy another key again!
Eternity Key is offline   Reply With Quote
Old 03-12-14, 11:17 AM   #41
HadYurPhil
Trader Score: (0)
How much is it?
HadYurPhil is offline   Reply With Quote
Old 04-05-14, 05:46 PM   #42
Eternity Key
Former Sponsor
Trader Score: (0)
There is finally a solution to the Lexus broken key problem!! The best replacement on the market is called the Eternity Key. The others break and its costly to replace over and over. The Eternity Key is made of military grade materials, stronger than anything on the market, and has a lifetime warranty. Available at Lexus dealers or see www.eternitykey.com for dealers.
Old 04-07-14, 08:21 AM   #43
HadYurPhil
Trader Score: (0)
Ignoring my question of how much is it...
Old 04-07-14, 11:06 AM   #44
salimshah
Trader Score: (0)
Quote:
At times it is intentional ... like prices can change and the reseller establishes the price etc
Visit the website or call dealer is the best suggestion I can make.
Salim
Old 04-16-14, 04:13 PM   #45
Eternity Key
Former Sponsor
Trader Score: (0)
Default Replacement key
Quote:
Originally Posted by Stemmer View Post
The original fob key shell for my '99 RX has separated, I have the key. Currently I am using the back up valet key but obviously I want this fixed. What is the best way? Dealer? Here is a company I found through an internet search - sounds like $15 for the shell and $30 for key shell cutting (which I don't really understand but assume it's to fit the key in the casing)http://www.autotransponder.com/1999_...key_shell_case
Anyone have this issue before? Any advice? Thank you in advance.
If you want a key that wont ever break on you go to your Lexus dealer and ask for our Eternity Key. It is a stronger tougher key made of military grade materials, and comes with a lifetime warranty. Go to www.eternitykey.com click on the video tab and you will see what I mean. Ask for it by name Eternity Key
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cheap Replacement Keys for GX! bareyb GX - First Generation 36 01-10-15 08:44 AM
Extra Key shell Code 46073 tz693 GX - First Generation 0 08-12-14 06:34 PM
TX FS:Lexus Programmable Wallet Key and Pre-cut Flip Key Fob Replacement Shell black04GS 2Gen GS430 / 400/ 300 Classifieds (98-05) 2 03-29-14 01:34 AM
Keyless shell case broke Mut RX - First Generation 10 10-22-11 09:03 PM
Tags
03, broken, car, case, casing, cracked, cutting, falling, fob, is300, key, keys, lexus, plastic, shell
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
