Filling A/C Freon
It came with 134A. Unless it has been wrecked and the hood replaced, there should be a sticker under the friont of the hood that designates system capacity. Somtimes the sticker is on the core support or elsewhere, but definitely under the hood. It doesn't take a lot, normally 1.3-1.6 lbs. Note that those are 16 oz. lbs. I don't know of any A/C charge that comes in 16 oz. cans., sometimes 14 oz, sometimes 13 oz.,sometimes 12 oz. On an '02, you MAY still have a sight glass in the system that would aid in adding correctly. Do a little research on this rather than just "adding" til it's cold. That's definitely the WRONG way to go about it!
The proper way to refill the A/C system is to first recover all of the freon from the system. And, then it's recommended you run a vacuum for at least 30 mins, even if the system hasn't been opened up. You then use a A/C Freon Scale to add the refrigerant. You also have to add PAG oil (verify by reading the sticker under the hood) for all of the components to stay oiled up.
