Driver Auto Windows up/down & door lock problem
Old 05-15-11, 10:15 AM
wing0
wing0's Avatar
Default Driver Auto Windows up/down & door lock problem
Got two problems and not sure if they're related.
The driver windows auto down/up function is no longer working. I have to hold the button in order for it to fully open and close. All other windows are fine.
This is rare, but sometimes when I try to unlock all 4 doors from outside, the driver door side doesn't automatically unlock. I have to resort to putting my key into the door and doing a manual unlock.
Old 05-15-11, 12:18 PM
salimshah
salimshah's Avatar
If it is one touch lower/raise not working, try reprogramming the pinch protection .. hold the button down and let the glass travel all the way down and the hold the button up and let the glass travel up all the way. Do that couple of times and then test the single flick.
Search door lock actuator for lock.
Salim
Old 05-15-11, 11:53 PM
wing0
wing0's Avatar
Salim
Tried several full up and down operation on the window. Auto function still not working for both directions.
Old 05-16-11, 09:35 AM
salimshah
salimshah's Avatar
If you are the DIY type, Lexmex posted a DIY on how to service the window regulator. I did not have enough faith and predicted that the fix will not last long. It has been many months and Lexmex has not had any problems.
Some serious diagnosis and repair is needed.
Salim
Old 05-16-11, 04:39 PM
Lexmex
Super Moderator
Lexmex's Avatar
Salim,
Your faith may have been in the right place.
My window still works...barely.
I recently bought another regulator (still in the box) but I hopefully will get to it tomorrow morning. I have a hunch at this point that my regulator is bent somehow (given issues last time with how the 10mm bolts lined up) and got one off of Amazon.com
However, I plan to also take a look at the control module on the driver's side door and its contact points.
TommyT
08-24-13 12:03 PM
DOHCZ34
Performance & Maintenance
11-14-09 10:39 PM
galletgun
IS - 1st Gen (2001-2005)
11-01-09 12:59 AM
Quick Reply: Driver Auto Windows up/down & door lock problem
