Dome Light and Middle Console Out! HELP!
I found the fuse!!! it was in the engine fuse box. The Dome fuse was blown. Thanks to everyone for their help. Saved me a lot of trouble.
did you end up fixing your radio and dome lights problem because i have the same problem on my car too and i dont know how to fix it,so if you could please help me out?
i opened the hood and looked at the fuse box in the hood. in the fuse box lid there is a table on which fuse is where and there should be a clip to take out the fuses. it should say dome or something. i'll take pics tomorrow if i get the time
Radio, clock, AC lights
Everything worked fine the night before and in the morning when I turn the car on the clock was off radio didn't turn on anymore and the lights for the AC was off. The AC is working fine besides the lights for the buttons are off. Can someone tell me how I can fix this problem?
I just went thru a similar experience where all the lights on my center console went out. I found out it was the 7.5A "Panel" fuse that was blown.
Not sure about the radio and clock though. Probably also due to a fuse. Check the auxiliary fuse box behind the "coin holder" box.
After reading a dozen or so threads, checking ever plug and most of the fuses I finally read this Thread. Sure enough my dome light fuse was blown. I would never had thought that was the problem.
Details
2000 RX300
No power to display/radio
Climate control working but no display
Solution
Blown 10A (red)"DOME" fuse engine fuse box.
Thank you all.
Details
2000 RX300
Solution
Thank you all.
rhack1
RX - 1st Gen (1999-2003)
12-26-09 07:11 PM
