My Transmission Problem, help!
Old 05-03-11, 02:27 PM
lserlohn
lserlohn's Avatar
Default My Transmission Problem, help!
Hello, all. I am suffering a serious transmission problem. I really don't want to get it replaced. I have carefully done experiments on this car, please see the symptoms:
When engine is cold:
1. At "P", When step on the gas, the Engine Speed can goes above 2000 rpm.
2. Shift "P" to "R", gear engages soon
3. Shift "R" to "D", gear hesitated about 3 secs.
4. Car runs fine, shifting is OK with a little jerk, all gear works. No slipping at all.
When engine is warm or hot:
1. Shift "P" to "R", gear engages soon
2. Shift "R" to "D", gear engages soon
3. The car is slipping at about 40 mph, today I finally figured it out that the car could not engage into gear 4. That is why the car always slip at about 40 mph, not at any other lower speed. (But it will engage when the engine is cold, strange......)
The check engine code :P0770, shift solenoid "E" problem, but after I research online, I found this is a generic problem. Shift solenoids does not fail easily.
The ATF is replaced last month, the level is fine, but I think this is the beginning of this disaster.
Please help me find where is wrong.
I don't trust local repair man, I think they are not professional.
I don't trust dealer, I think what they are going to do is replace the whole transmission.
I only trust people here.
Great thanks in advanced.
Old 05-03-11, 04:32 PM
99rx
99rx's Avatar
You should probably start off by dropping the pan and replacing the filter... That way you can see if there is any debris in the fluid or on the magnets. So start with that and report back.
Jason
Old 05-03-11, 04:59 PM
thomas1
thomas1's Avatar
when you had atf replaced did you use Toyota Type IV? And did you have a flush done or a drain and fill...by the way we do not recommend flushes...And no matter what anybody tells you the flush will not fix your problem, been there done that...
Old 05-03-11, 09:18 PM
Rhdcrxsir
Rhdcrxsir's Avatar
Good luck. Hope you fix the problem
Old 05-07-11, 10:07 PM
dindih
dindih's Avatar
lserlohn,
What had happened since 5/3, did anything change ? Any good news ?
I may be having similar problems, 2000 RX300 AWD 107K, tranny fluid changed at 100K and again at 105K (both are drains and pan drops with refills) at a national Transmission chain shop with ATF Type IV. After the second change, rough gear changes from 1-2 and 2-3, especially cold, then less so when the car is warmed up.
Yesterday, my wife called in panic reporting awful metal sound from the transmission and very rough gear changes. She parked in a public parking spot and now the car does not engage in R at all. It still engages in D going forward but very rough with some sound. No CEL ? The fluid level is right on spot.
I will drop the pan after draining both plugs and add fresh ATF Type IV, as much as I drain, then check. See if there are any metals or metal dust !
Old 05-09-11, 05:43 AM
buset
buset's Avatar
it happen to my mine too, what i did is drop the pan and change the filter and refill drive around the block and drain / fill 3 times and from there see what happen.. goodluck
Old 05-09-11, 12:58 PM
salimshah
salimshah's Avatar
Originally Posted by dindih
lserlohn,
Check if ATF IV is the same or better than Toyota ATF IV. If not then you have something to complain about.
Salim
Old 03-04-18, 06:06 PM
Grx300
Grx300's Avatar
Dindih, you have any success? I just got home from dinner and my Rx did almost the same thing. Slipped out of reverse then wouldn't engage in at all. Right starts from complete stop.
atdprod
04-30-11 07:35 PM
rickyp39
11-05-10 12:18 PM
pennda
09-27-07 06:32 PM
Ariyanna
08-03-07 07:24 AM
Quick Reply: My Transmission Problem, help!
