99 RX300 rear hatch stuck
Old 08-29-02, 08:30 PM
lexus_mark
lexus_mark's Avatar
Question 99 RX300 rear hatch stuck
Anyone had any problems with the rear hatch not opening.
The hatch is unlock but will not open.
Old 08-29-02, 08:35 PM
Shacky
Shacky's Avatar
Default Yes
I push down on the hatch while pulling the latch. That unsticks it for me.
Old 08-29-02, 08:38 PM
lexus_mark
lexus_mark's Avatar
thanks i'll try that because just pulling it don't work.
Old 08-29-02, 09:06 PM
salimshah
salimshah's Avatar
Caution:
Be gentle as you push the trunk/door/hatch down. I had the same problem and made it worse by pushing the hatch couple of inches below the license plate and caused dimple in the sheet metal.
I had to get the dealer to fix it.
When the trunk is locked and you squeeze the open/lift lever/handle, does the handle move without releasing or does it feel stuck. Ever since the dealer fixed the release, the hadle in lock position can be squeezed for me. Before that it could not be moved till I unlock the hatch.
Salim
Old 08-29-02, 10:21 PM
Sooner
Sooner's Avatar
there is a tsb to fix this contact your dealer
Old 08-29-02, 10:25 PM
CK1_RX3
CK1_RX3's Avatar
Yeah, dealer just fixed this problem for me because it has been reported as a common issue with the RX... Hey, at least we don't have all the problems of the X5 and MDX right???!!!
ck
Old 08-30-02, 11:54 AM
lexus_mark
lexus_mark's Avatar
I tried pressing down and pulling the hatch didnt work.
took it to the dealer. he order parts but the down side is it on national back order so i don't no when the part it going to come in. With out the hatch opening i can't change the tail light bulb thats out
Old 08-30-02, 01:03 PM
HarrierRX300
HarrierRX300's Avatar
I had the same problem with the trunk latch. Bring it back to Lexus. They'll change the locking mechanism for you as well. I do notice if I'm on a hill, the closing part, it makes a "klunk" when I close the trunk. Is this normal? Flat land is ok though.
Old 08-30-02, 03:10 PM
Jonnystan
Jonnystan's Avatar
ya my house is on a hill and mine makes the same noise. Been doing it for months and never had a problem...i think it is normal.
Old 09-02-02, 01:20 PM
parula
parula's Avatar
Take it to the dealer, they will fix it, there was a fix designed for this problem that worked ok on mine.
When they have it opened up (and the rear panel on the hatch comes off pretty easily), take 1" thick or so by 2" wab of softttt foam and place it between the small wire that amounts to your latch connector and the hatch door. Probe around and wiggle the mechanism you will see what rattles, at least mine did and I did it with the tech. THis will nicely keep the latch cnnector from rattling around, IMO it seems very "loosely" designed, even the tech. said that a was a great fix and the hatch was quiter.
When you close your hatch you noice an immediate improvement in the quiteness of the door with this remedy. It will sound like a new Honda door closing. Took a look at the new Honda Civic Si over the weekend and closed the doors. Then went home and closed the doors on my $35k Lexus. No comparsion IMO, the Honda was tighter!
Old 05-19-09, 04:18 PM
furball
furball's Avatar
This seems to be an extremely old thread, but the 1999 RX 300 we have has this issue... The latch underneath doesn't even budge sometimes, and we have to try unlocking using the key remote a few times...
Does anyone have the actual TSB, TSB number, etc? Is it still active?
Any fix that we can do, or is it 100% dealer? (i.e. put grease on it, etc.)
AngelStory
RX - 3rd Gen (2010-2015)
03-20-17 06:24 AM
Luisame
07-25-14 01:28 PM
johnchi
11-30-11 08:22 AM
biodev
05-14-10 06:06 AM
Quick Reply: 99 RX300 rear hatch stuck
