Today upgraded front door speakers and sound quality 70% better
Old 03-17-11, 09:50 PM
gazi001
gazi001's Avatar
Default Speakers upgrade diy front and rear doors
Finaly today evening i replaced both front door stock speakers with infinity reference 6032si. Now all doors speakers (front & rear) are new infinity speakers.
Compares to old stock speakers now the sound quality much much better about 70% improved. Here some pics...........
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-infinity-6032-si.jpg   Today upgraded front door speakers and sound quality 70% better-photo-3-.jpg   Today upgraded front door speakers and sound quality 70% better-front-r-door-trim.jpg
Old 03-18-11, 05:06 AM
99rx
99rx's Avatar
Was it a fairly easy upgrade? Would you consider writing up a DIY? I have my front passenger that I think is going and would like new speakers to just make the whole radio sound better.
Old 03-18-11, 11:20 AM
gazi001
gazi001's Avatar
You have to replace all doors speakers front & rear to get better sound. I got those speakers from crutchfield.com and they will give you necessary adapter and speaker harnesses. I will post more diy in the weekend. If you interested let me know.
Old 03-18-11, 01:22 PM
felixdang
felixdang's Avatar
Will the oem amp work with the new speakers or did u have to replace the amp too?
Old 03-18-11, 02:40 PM
99rx
99rx's Avatar
Yes I'm interested if you are willing to share.
Old 03-19-11, 12:32 PM
gazi001
gazi001's Avatar
You need to buy two pairs of front & rear doors speakers, like i bought Infinity Reference 6032si & 6032cf from crutchfield.com. If you use this code: 3A825 you will get $20 off orders $100. If you make two separate orders you will get total $40.00 off. Each speaker priced in crutchfield for $99.99 with free adapters and harnesses (about $25.00 value).
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-infinity-speakers.jpg
Old 03-19-11, 12:33 PM
gazi001
gazi001's Avatar
Felixdang, OEM amp works fine with new speakers.
Old 03-19-11, 12:55 PM
gazi001
gazi001's Avatar
Before you install those infinity speakers you need to brace the speaker adapters(which comes with speaker box) with SAT-6 adapter which free provided by crutchfield. Make sure the speaker adapter round shape by cutting the edge (triangle outer side for screws) with plastic cutter scissor. Then sit this adapter on the top of the sat 6 adapter and make small holes (4) with drill according to brace the speaker adapter by #4-40X 1/2" flat head philips screws, #6S washer (which i bought from homedepot).
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-scissor-screws-washer..jpg
Old 03-19-11, 01:00 PM
gazi001
gazi001's Avatar
Followings are the: speaker, speaker adapter(middle) and SAT 6 adapter at the right.
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-photo-8-.jpg
Old 03-19-11, 01:03 PM
gazi001
gazi001's Avatar
Now you can sit the speaker top of the braced adapter with same screws in four side. Here is the braced speaker with adapters.
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-braces-adapter.jpg
Old 03-19-11, 01:05 PM
gazi001
gazi001's Avatar
Back side of the braced speaker connected with toyota harnesse (free provided by crutchfield) for easy connection to factory speaker connection.
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-braces-backside.jpg
Old 03-19-11, 01:21 PM
gazi001
gazi001's Avatar
Follow this nice door removal DIY by Lexmex to remove the front door panel: https://www.clublexus.com/forums/rx-...moval-diy.html
After remove the door panel you will see 3 screws hold the speaker. Unplug the speaker cable and remove the old speaker. Remember when you brace the speaker with braced adapter try to keep the speaker connection & SAT 6 cable hole at the top. This way it will easy to connect with factory cable.
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-photo-3-.jpg
Old 03-19-11, 01:32 PM
gazi001
gazi001's Avatar
Remove the rear door panel same like front door except the middle door panel screw is hidden behind this small plastic trim. you need to remove this plastic piece by small flat head screw driver. See pics.(red circle piece need to remove):
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-before-remove-the-small-trim.jpg   Today upgraded front door speakers and sound quality 70% better-after-remove-the-small-trim.jpg
Old 03-19-11, 01:44 PM
gazi001
gazi001's Avatar
Follow the same way to install the rear door speakers. Infinity speaker has tweeter-level control switch in the speaker which you could adjust it before put back the panel. It took about 30 minutes to remove the each door panel and more extra time for brace the adapter. Good luck.
Here picture installed speaker in rear:
Attached Thumbnails Today upgraded front door speakers and sound quality 70% better-left-side-installed.jpg
Old 03-19-11, 01:50 PM
gazi001
gazi001's Avatar
99rx, If you need any more help let me know.
mdk87
ES - 6th Gen (2013-2018)
34
10-27-21 03:47 PM
romwarrior
04-22-13 08:01 AM
tftimm
SC- 1st Gen (1992-2000)
03-21-12 09:49 PM
olddog
04-08-07 09:04 PM
Baker Bootleg
05-04-02 07:39 PM
Quick Reply: Today upgraded front door speakers and sound quality 70% better
