Red "BRAKE" Warning Indicator and Chime
Old 07-11-13, 04:16 PM
gazi001
gazi001's Avatar
Originally Posted by pushtree
Replacing the brake fluid reservoir cap is an easy fix, about a minute of time, and it cured the problem. I think the part # is 84460-30040
You got it. I had same issue.
Old 07-11-13, 05:34 PM
trhs75
trhs75's Avatar
Isn't that amazing? I mean, who would have ever guessed that would be the problem. If it hadn't been for the advice on this board, I might have gone crazy from the noise and jumped out the
window!!
Old 08-05-13, 04:08 PM
milker
milker's Avatar
Default Red "BRAKE" Warning Indicator and Chime
After reading some of the answers, I noticed my reservoir was almost to the top, so I thought that the fluid may be getting into the top of the sensor, I slid the robber cap off the sensor a little to see the top of the sensor, I sprayed the top of the sensor where the wires go into the sensor with brake cleaner and waited till it was dry, I sucked some of the fluid out of the reservoir with paper towel and left it on the fill line. Put everything back on and no more light, it took about 5 minutes. Hope this help someone save $100 on a new sensor.
Old 08-05-13, 04:29 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,099 Likes on 989 Posts
Were you over the max line? And has the fluid darkened .... I use clear and my reservoir shows clear fluid. Old fluid starts getting gummy and would prevent smooth float operation.
Salim
Old 12-02-13, 02:31 PM
steven4422
steven4422's Avatar
Replacing the brake fluid reservoir cap? will that work on a 2008 lexus rx350. same issue: brake light on constant, chime. Brakes are fine.
Old 12-02-13, 04:59 PM
salimshah
Forum Moderator
salimshah's Avatar
Have a helper see the instrument cluster as you slide the float up and down.
Salim
Old 12-02-13, 06:58 PM
maxSteel
maxSteel's Avatar
Originally Posted by milker
, I sucked some of the fluid out of the reservoir with paper towel and left it on the fill line. P.
I keep one of those medicine syringes (the kind for squirting medicine in a kids mouth) in my toolbox just for removing excess brake fluid.
Old 12-02-13, 08:24 PM
salimshah
Forum Moderator
salimshah's Avatar
I use the flavor injectors. Just added another one this Thanksgiving.
Salim
Old 12-05-13, 08:06 AM
torii007
torii007's Avatar
Default Brake light and chime
I had the same problem with our 2000 RX300. The solution was to replace the brake reservoir cap assembly (all one part). I had to order one from the Lexus parts department. I simply unplugged the old cap, removed it, and then installed the new one. It was a very easy process.
Old 03-01-14, 02:49 AM
joebtflspk
joebtflspk's Avatar
Default brake warning light
Has happened to me during very cold spells. Popped hood, thumped rim of brake reservoir top a couple of times with my finger, problem disappeared. Apparently loosens sensor float to its proper level. Cheap solutions are the best!!
Old 03-01-14, 06:48 AM
carguy07
carguy07's Avatar
That would make me question if the fluid is contaminated with water and needs changed.
Old 01-24-15, 12:54 PM
gregmacd
gregmacd's Avatar
I replaced the brake fluid reservoir cap (part # is 84460-30040) on my 1999 RX300, which I found on ebay for $80 and the problem went away thanks to all the previous posters who said to do the same thing!
5 years ago, the brake light came on, and it went away after I added some more brake fluid, but that didn't work this time. So, try adding brake fluid first, before you replace the part.
Old 01-25-15, 08:01 AM
trhs75
trhs75's Avatar
Excellent tip from Greg. Hopefully, it will just be a matter of making sure there's enough fluid. That's a lot cheaper than a new cap, too!
Old 02-11-15, 03:57 PM
jnotebaert
jnotebaert's Avatar
Default Brake Fluid Cap
Hey LA4Mead,
Do you have the site and part # to where you bought the brake fluid cap for your RX 300? I have a 99 and that brake light is ding ding dinging me crazy!!! I googled "brake fluid cap" and price ranges came up from $30-$90 bucks and I want to make sure I don't buy junk or pay too much. thanks- Jack, Phoenix AZ
Old 02-11-15, 06:08 PM
trhs75
trhs75's Avatar
I think it's 84460-30040. I've bought a couple, and they were each just under $100.
Quick Reply: Red "BRAKE" Warning Indicator and Chime
