Hi, Just Joined
Hi, Just Joined
I am tickled to find this forum.
My wife just bought a 2000 RX300 and I am having a few probs.
The power antenna would not go up and down, just stayed extended. Further investigation revealed that the previous owner had atempted to install a universal power antenna motor and mast. In doing so they cut the pigtail off that plugs into the motor. I have a new motor and have ordered what I hope is a pigtail for the motor from Sewell's Auto Parts. We shall see. Any reliable places to order parts for Lexus on line?
Another problem is the engine light. My mechanic, not an authorized Lexus guy, runs diagnostics, resets everything and after a few start ups the engine light reappears. Is this common?
Additional minor problem. Battery life runs down quickly. For instance, interior lights left on or running the radio without the engine on runs the battery down pretty quickly. Battery test at the local parts warehouse indicate the battery is good. Common?
Again, I am very pleased to find this forum. Hope you can help out.
Super Moderator
The antenna issue I know has been discussed here before, and I am going to defer to some group members on this as I haven't had this issue occur before.
With the engine light, there is a code that can be pulled up with the same device that is used to clear it, usually like say P0171 or some other code. Get that code and post it here and we can help you diagnose it.
How long have you had the battery in question?
Welcome to the group. Everyone here has been so helpful to me. I've had the antenna issue before -- I replaced the mast with a Lexus mast once, but eventually I had to replace the whole assembly with a salvage one. New ones run bout $160 from online Lexus vendors like Sewell , irontoad, and rockauto mentioned around this forum. I've had good luck with them!
be sure all the hoses are connected behind the aIr filter. Quick lube oil joints always knock the hose loose when changeing the air filter. Take flashlight and look behind filter and down.
This site had it for $137 plus shipping
http://www.trademotion.com/partlocat...82&catalogid=0
look in electrical/body electrical/antenna and radio/antenna
Hi-psi
SC- 1st Gen (1992-2000)
17
10-12-03 02:11 PM
