Fuel pump fuse
Old 01-07-11, 03:05 PM
LowRX
LowRX's Avatar
Default Fuel pump fuse
Anyone know where it is located at? I am not getting power to the pump on the RX. I cant seem to find it on the fuseblock in the engine bay or under the dash. Ideas? IS there maybe an inline fuse?
Old 01-07-11, 03:52 PM
salimshah
salimshah's Avatar
The power to the pump is not by a straight run.
The following is based on my understanding of electronic fuel lift pumps for vehicles (RX may have a different solution)
The power is driven from a circuit that provides ignition ... as long as the plugs are energized and sparking (engine running) the pump gets +12v. Once the ignition is dead the pump is cut off. This prevents gasoline to be pumped out by a cut in the pipe in case of an accident.
The circuit has another circuit built on top that allows the pump to be energized when the key is either inserted in the ignition to let the pump prime up.
Hope this helps and appreciate the engineering that goes into building the vehicles.
Salim
The process to check the pump out is by bypassing the safety circuit. If you have access to service manual you will find it there. In case you dont own one, you can purchase access form alldata (or something similar)
Old 01-07-11, 09:27 PM
Nad1370
Nad1370's Avatar
There is no fuse for the fuel pump.
But there is a relay.
It's called a Circuit Opening Relay, located in the drivers lower finish panel.
Back probe the Black/Red tracer wire to see if you have power. (engine cranking). This wire goes straight to the FP.
If you think it's the relay an you don't have another relay to compare it to. Just grab the horn relay under the hood. Black cover near the battery.
Attached Thumbnails Fuel pump fuse-cir-op.jpg   Fuel pump fuse-copy-of-img_0002.jpg
Old 12-09-20, 06:42 AM
rickz713
rickz713's Avatar
Hi. Help me to understand this diagram. I'm trying to find the circuit opening relay. I don't see anything in the driver's lower finish panel that looks like the horn relay. I'd like to switch the horn relay with the circuit opening relay but I can't find the circuit opening relay under the dash. Never mind... just realized the fuse is BEHIND the panel.
9Dragnfly2
Performance & Maintenance
08-07-16 06:45 PM
Brianmoss
06-08-13 02:51 PM
attzor
01-13-10 05:36 AM
sc300vroom
SC- 1st Gen (1992-2000)
11-07-09 08:31 PM
BLAZE
GS - 1st Gen (1993-1997)
03-11-09 04:32 PM
Quick Reply: Fuel pump fuse
