What other factory wheels did you fit?
I know that Rx300, Rx330, Rx350, Rav4, harrier and klugger wheels all should bolt on without issues.
What other toyota nissan ford or lexus wheels fit? enough offset etc
What other 114.3 x 5 stud patterns will fit?
camry, 370zx, ford sedan, Skyline all will likely fit but have you?
I know that after market wheels are available but often factory wheels come up for sale at a reasonable price. I am currently looking for a spare wheel as the guy that sold me my ride kept it along with the jack. But interested to see what else looks nice on a rx300.
Any recommendations for the jack as it needs to get high enough to change the tire and i don't think sedan jacks get high enough. I don't feel like lugging one of those long 4x4 jacks just want something stock or like it that i cant fit out of sight.
LEXUS YEAR OE SIZE BOLT LUG/NUT CENTER BORE ET
ES 250 90-91 15 X 6 5X100 12mmX1.5 54.1 35-45mm
ES 300 92-97 15 X 6 5X114.3 12mmX1.5 60.1 35-45mm
GS 300 93-on 16 X 7.5 5X114.3 12mmX1.5 60.1 35-45mm
GS 400 98 16X7.5 5X114.3 12mmX1.5 60.1 35-45mm
GS 430 01-on 17 x 7 5X114.3 12mmX1.5 60.1 20mm
IS 300 2000-on 17 x 7 5X114.3 12mmX1.5 60.1 35-45mm
LS 400 90-94 16 X 7 5X114.3 12mmX1.5 60.1 35-45mm
LS 400 95-on 16 X 7 5X114.3 12mmX1.5 60.1 20mm
LS 430 2000-on 16 X 7 5X114.3 12mmX1.5 60.1 20mm
SC 300 92-96 16 X 6.5 5X114.3 12mmX1.5 60.1 35-45mm
SC 400 91-on 16 X 7 5X114.3 12mmX1.5 60.1 35-45mm
SC 430 8 2002-on 18x8.5 5x114.3 12mmX1.5 60.1 35-45mm
LX 450 96-97 16 X 8 6X139.7 12mmX1.5 108 20mm
LX 470 97-on 16 x 8 5x150 - 110 35-45mm
RX300 98- 16x7 5x114.3 12mmX1.5 60.1 20mm
TOYOTA YEAR OE SIZE BOLT LUG/NUT CENTER BORE ET
AVALON 95-97 15 X 6 5X114.3 12mmX1.5 60.1 35-45mm
CAMRY 83-91 13 X 5 5X100 12mmX1.5 54.1 35-45mm
CAMRY 92-on 14 X 6 5X114.3 12mmX1.5 60.1 35-45mm
CAMRY SOLARA 99-on 16 X 6 5X114.3 12mmX1.5 60.1 35-45mm
CELICA 76-85 14 X 6 4X114.3 12mmX1.5 60.1 20mm
CELICA 86-91 13 X 5.5 4X100 12mmX1.5 54.1 35-45mm
CELICA 86-96 14 X 6 5X100 12mmX1.5 54.1 35-45mm
CELICA 90-96 15 X 6 5X100 12mmX1.5 54.1 35-45mm
CELICA 2000-on 15 X 6 5X100 12mmX1.5 54.1 35-45mm
COROLLA 88-96 13 X 5 4X100 12mmX1.5 54.1 35-45mm
COROLLA 88-97 14 X 5.5 4X100 12mmX1.5 54.1 35-45mm
CRESSIDA 85-88 15 X 6 4X114.3 12mmX1.5 60.1 20mm
CRESSIDA 89-92 15 X 6 5X114.3 12mmX1.5 60.1 35-45mm
ECHO 00-on 13 X 4.5 4X100 12mmX1.5 54.1 35-45mm
MR-2 85-89 14 X 6 4X100 12mmX1.5 54.1 35-45mm
MR-2 90-92 14 X 6 5X114.3 12mmX1.5 60.1 35-45mm
MR-2 92-95 15 X 7 5X114.3 12mmX1.5 60.1 35-45mm
MR-2 SPYDER 00-on - 4X100 12mmX1.5 54.1 35-45mm
PASEO 92-96 14 X 5.5 4X100 12mmX1.5 54.1 35-45mm
PRIUS 01-on 4X100 12mmX1.5 54.1 35-45mm
SUPRA 79-82 14 X 6 4X114.3 12mmX1.5 60.1 20mm
SUPRA 93-96 16 X 8 5X114.3 12mmX1.5 60.1 35-45mm
SUPRA 93-96 17 X 8,F 5X114.3 12mmX1.5 60.1 35-45mm
SUPRA 93-96 17 X 9,5,R 5X114.3 12mmX1.5 60.1 35-45mm
SUPRA L 83-85 15 X 6 4X114.3 12mmX1.5 60.1 20mm
SUPRA,TURBO 86-93 16 X 7 5X114.3 12mmX1.5 60.1 35-45mm
TERCEL 83-97 13 X 4.5 4X100 12mmX1.5 54.1 35-45mm
PICKUP 2WD 80-95 14 X 6 5X114.3 12mmX1.5 - 0mm/20mm
PICKUP 4WD, 4 RUNNER 80-95 15 X 7 6X139.7 12mmX1.5 - 0mm/20mm
4-RUNNER 96-97 16 X 7 6X139.7 12mmX1.5 - 20mm
4WD PICKUP 86-95 15 X 6 6X139.7 12mmX1.5 - 0mm/20mm
HIGHLANDER 01-on 5X114.3 12mmX1.5 60.1 20mm
LANDCRUISER 69-92 15 X 6 6X139.7 12mmX1.5 - 0mm/20mm
LANDCRUISER 93-97 16 X 8 6X139.7 12mmX1.5 - 20mm
LANDCRUISER 98-on 16 X 8 5X150 14mmX1.5 110 35-45mm
PREVIA 90-94 14 X 6 5X114.3 12mmX1.5 60.1 35-45mm
PREVIA 91-96 15 X 6 5X114.3 12mmX1.5 60.1 35-45mm
RAV4 96-97 16 X 7 5X114.3 12mmX1.5 67.1 35-45mm
RAV4 00-on 16 X 7 5X114.3 12mmX1.5 67.1 -
SEQUOIA 01-on 16 X 7 6X139.7 12mmX1.5 108 20mm
SIENNA 97- 15 X 6 5X114.3 12mmX1.5 60.1 35-45mm
T-100 93-96 15 X 6 6X139.7 12mmX1.5 108 20mm
TACOMA 2WD 95-97 14 X 5.5 5X114.3 12mmX1.5 67.1 20mm/35-45mm
TACOMA 4WD 95-97 15 X 7 6X139.7 12mmX1.5 108 20mm
TUNDRA 99-on 16 X 7 6X139.7 12mmX1.5 108 20mm
VAN WAGON 2WD 84-90 14 X 5.5 4X114.3 12mmX1.5 - 20mm
source http://www.members.***.net/dlong18/wheelpat.html
http://www.miata.net/garage/tirecalc.html
no, haven't noticed any issues so far though. the rear spacer is a a universal also, so no hub ring there either. IMO i think the lugs do a pretty good job at centering the wheels since they go in so deep in the wheel.
The Toyota Venza 19" and 20's fit perfectly without spacers, hub rings, etc.
The factory tires fit too. Look for a set of take offs on craigslist or local dealer for a good $$. I like the look of them in my RX.
Hub sentric is is different from lug sentric. You really need a lug centric hub adaptor. The Rx300 is hub and lug sentric if the center of the wheel does not fit on the hub the wheels can be unsafe as the bolts do not center the wheels alone.
My tires were getting bald and i found a set of RX330 wheels 17" for $550 with road worthy tires on ebay and have bolted them on with no problems direct fit. I am not so fussed now on larger wheels and i am disliking spacers i had a wheel come off with the spacer on my other car just this week so am not going to use them on this car. I am really appreciating the amount of air and rubber between the rim. The newer wheels certainly give the car a modern look and i am sure my wheels will make a nice upgrade for a rav4 as will include my center caps. I did test fit aftermarket 19 inches but need to buy 55 profile tires for this car which will cost $1000 here. I am now contemplating selling
my 19's now as well as i like the 17s so much as i prefer stock wheels.
