Fog lights not working
Old 01-05-11, 08:45 PM
JohnDeere
JohnDeere's Avatar
Question Fog lights not working
Ive got a 99 RX300 and the fog lights haven't worked since I bought it last week. I checked the fuse and it was good. Is it possible both of the bulbs are burned out? Also how do I get to those bulbs. They seem quite buried. Any help would be appreciated!!
Old 01-05-11, 09:25 PM
defo
defo's Avatar
Probably just burned out. Changing them sucks.....IIRC, you have to take out some screws and/or plastic snaps from the wheel well liner, fold it out of the way, then you should be able to access the foglight bulb. (turning the wheel away from the light you are working on helps big time)
Old 01-05-11, 11:26 PM
salimshah
salimshah's Avatar
Do the fog lights come on when you have parking lights on? [First click] ... the fogs turn off when the high beams are on.
Salim
Old 01-06-11, 12:37 PM
Peter5767
Peter5767's Avatar
Read the Owner Manual, make sure you turn the fog light on.
Also check the thread about disable day light driving.
Then go to the bulbs.
Old 01-06-11, 12:42 PM
bob2200
bob2200's Avatar
Just to make sure you are aware, there is a fog lamp switch on the headlight stalk.
Old 01-07-11, 06:44 PM
JohnDeere
JohnDeere's Avatar
Question
Are the DRL wired in with the fog lights? Also the fog lights don't come at all no matter weather I have the headlights on or not and also with the high beams off. Anyone know if there is a DIY fog light replacement thread with pics? Thanks!
Old 01-07-11, 09:05 PM
defo
defo's Avatar
DRL are actually your high beam light being turned on at about 50% power or less
Old 01-07-11, 10:31 PM
JohnDeere
JohnDeere's Avatar
I understand that but as Peter5767 suggested, he said to check the thread about disable day light driving so I was wondering with him suggesting this that he ment the fog lights were wired in with the day time running lights. Just so I am clear, I am talking about the FOG lights (the one that is circled in red in the pic) that are not working, not the day time running lights. I apologize if I was confusing
Old 01-08-11, 08:20 AM
salimshah
salimshah's Avatar
The problem is diagnosing across the net and doing it without sounding rude.
If both (left and right) are not working, a good assumption is they are not getting 12v (both bulbs can pop too).
The fog light switch must be ON (on the stalk)
Lights must be ON but at low beam (normal) setting {no high beam .. blinding**
There is an interdependence, and we are talking with the set up that has not been messed around.
Access to one fog light is easier than the other. Pull the bulb out and check and you can check for 12v after ensuring the things above are set.
All the above is for completeness and should not be construed as being rude.
Salim
Old 01-08-11, 08:25 AM
JohnDeere
JohnDeere's Avatar
I was not meaning to sound rude, I just thought maybe you guys thought I was meaning that the DRL were not working. I do appreciate everyones input.
Old 01-08-11, 09:11 AM
salimshah
salimshah's Avatar
You were definitely not rude. I was worried that I may be the one ... stating some of the obvious like turn the light switch on etc.
Salim
Old 01-08-11, 10:12 AM
JohnDeere
JohnDeere's Avatar
No offense taken . Bad news though, I finally pulled both fog lamp bulbs to which they were both good. With the fuse not being blown and bulbs that are also not blown, it would point to an electrical problem somewhere.
Old 01-08-11, 11:00 AM
defo
defo's Avatar
The most logical problem, would be a bad relay.....I would suggest you check that next.
I would tell you where that is, but I don't know.....I'm sure someone here can chime in about the fog light relay location
Old 01-08-11, 11:45 AM
JohnDeere
JohnDeere's Avatar
Found the relay location here: http://www.lexuspartsnow.com/compone...01-2220~3.html That is an awsome website if your trying to track down electrical stuff! Im gonna head to Schucks and throw in a new one to see if that fixes it. Keep your fingers crossed for me!
Old 01-08-11, 01:17 PM
JohnDeere
JohnDeere's Avatar
Damn, just threw in the new relay and the fog lights still aren't working!! What next??
KJLegend
04-24-10 05:28 AM
jvsc300
SC- 1st Gen (1992-2000)
22
01-11-09 07:25 AM
cam69ss
06-28-05 02:19 PM
dinh626
Lighting
04-16-04 01:34 AM
Quick Reply: Fog lights not working
