Can't figure out how to remove door handle???
Old 01-01-11, 05:17 PM
2002RX300
2002RX300's Avatar
Question Can't figure out how to remove door handle???
Hey all, I can't seem to figure out how to remove the door handle on the drivers side door (don't want to pull too far out and break the plastic rod holders). I have all the inner door paneling removed and looks like I'll have to remove the door handle and disconnect the two rods leading to the actuator. What is the best method of removing/disconnecting these two rods for removal of the door lock actuator?
Thanks
Old 01-03-11, 02:36 PM
2002RX300
2002RX300's Avatar
Unhappy
Nothing?!
How about a service manual? Does anyone know where to download a service manual?
Thanks
Old 01-03-11, 04:30 PM
salimshah
salimshah's Avatar
I did the SC so most likely the same process will apply.
You do not need to remove the handle.
the rods pass through a hole and you will see plastic surround .. this helps glide the rod at the connector. The plastic has a portion that reaches over the rod and locks on to it ... this prevents the rod from slipping out. You have to flip the plastic clip up and free the rod. Once flipped up the rod comes out of the hinge.
The front door has the key lock mechanism along with the door release handle.
This is why I think the piggy back solution is the most convenient way.
Salim
LexGS3
02-06-16 07:35 PM
Tom57
08-13-15 10:08 AM
unknown101
Performance & Maintenance
05-09-15 10:54 AM
Fikus
10-03-10 04:23 PM
Dx3
SC- 1st Gen (1992-2000)
10-06-04 05:39 PM
Quick Reply: Can't figure out how to remove door handle???
