Front end clunk?--> Diagnose sway bar links
Old 04-29-10, 05:18 PM
Nad1370
Nad1370's Avatar
Default Front end clunk?--> Diagnose sway bar links
Tools needed:
--14mm socket/Wrench
--Vise Grips<-->You can use an allen wrench also to hold the thread bolt but they're usually rusted and round off.
Use appropriate size vise grip to get in between the link and mount hole.
Be carefull not to rip the boot out.
--Hand ratchet
Of course you need to jack the front of the vehicle on jack stands and pull both wheels off.
All you need is to take the top nut out and check for play.
Move the whole bar up/down to check the bottom joint for play.
I know the Strut top mounts are more common with front end clunk.
But you phisically need to take the whole strut assembly out and need a spring compressor to take it apart.
This is a 20min job to rule out the sway bar link.
Happy Wrenching.
Attached Thumbnails Front end clunk?--&gt; Diagnose sway bar links-img_4369.jpg   Front end clunk?--&gt; Diagnose sway bar links-img_4371.jpg   Front end clunk?--&gt; Diagnose sway bar links-img_4372.jpg   Front end clunk?--&gt; Diagnose sway bar links-img_4358-copy.jpg   Front end clunk?--&gt; Diagnose sway bar links-img_4359-copy.jpg
Old 04-29-10, 05:38 PM
hypervish
hypervish's Avatar
This should go into the DIY sticky.
Old 04-29-10, 10:59 PM
1nablxsonr
1nablxsonr's Avatar
Can I 2nd the motion to put this into the DIY sticky. Very well illustrated Nad1370, thank you very much.
Old 04-30-10, 04:29 AM
Lexmex
Super Moderator
Lexmex's Avatar
He can freely list it here, https://www.clublexus.com/forums/rx-...x300-diys.html
Any other member with DIYs can feel free to add them to that thread at any time of their choosing.
Old 04-30-10, 09:20 PM
carguy07
carguy07's Avatar
Makes you wonder how long these components would last if you were able to grease them instead of the current greased/sealed for life nonsense.
Old 04-30-10, 09:43 PM
salimshah
salimshah's Avatar
The grease nipples were also a source to introduce dirt and I had to learn when to stop pumping more grease. At that time the expected life was 100k, so with the sealed arrangements you do get about 100k.
Code is not the only person with an eye for details. The joint with a gap picture is very instructive but the part has no sheen and seems to be out of commission for a while ... with all the rust.
Nad1370, love your posts and pictures. It seems your RX has been giving you lots of frequent flyer milage as it has been on the jacks quite a bit.
Salim
Old 04-30-10, 11:25 PM
Nad1370
Nad1370's Avatar
Salim
Thanks Salim. You too. Throw out those "Matlock" VHS tapes already. lol
I've been putting it off for a while since my wife drives it 80% of the time.
She could care less of the noise (I don't even think she knows theres a problem)
We have decent roads here in the burbs' so it doesnt "clunk" as much.
I'm at 161k. No major problems to date. I love this thing.!
Old 12-04-12, 09:59 PM
imherenow
imherenow's Avatar
ya i know its old thread but now i will have to change it on my car. Also you guys mentioned about greasing the joint area right? so how much grease to apply or should i just leave it. thanks
Old 12-05-12, 07:44 AM
reisjdmd
reisjdmd's Avatar
this is an excellent post. if you ever do the rear suspension, and have not already done so, can you do the same kind of picture post. my rear clunks over bumps.
flipmode64
11-03-16 02:18 PM
99rx
Suspension and Brakes
12
09-03-16 06:45 AM
Ariyanna
07-17-07 08:26 PM
madmadrid
12-16-02 12:53 AM
Shinchan
13
08-30-01 08:13 AM
Quick Reply: Front end clunk?--> Diagnose sway bar links
