engine knock
Old 02-25-10, 03:20 PM
palaka
palaka's Avatar
Default engine knock
Need help with my rx 300 year 2000 120.000 miles i was told that one of my valve lifter is making that noise . The knock does not go away even after the engine warms up.i do cahnge my oil every 3000 miles im using penzoil platinum syn. Oil.so what do i do with the knocking noise?
Old 02-25-10, 03:43 PM
sktn77a
sktn77a's Avatar
Try AutoRx. I don't have any personal experience with it but some people here speak very highly of it.
Old 02-25-10, 03:51 PM
Nad1370
Nad1370's Avatar
No miracle oil will solve your knocking problem.
It could be a worn out lifter and hopefully it did not damaged the head.
You need to figure out which lifter it is. Maybe you get lucky and it's in Bank 2 ( radiator side)
If it's a broken valve spring. It's still doable w/out taking the head off.
Worse case scenario is a broken valve.
Old 02-25-10, 04:07 PM
Lexmex
Super Moderator
Lexmex's Avatar
Who told you the valve lifter was bust?
Old 02-25-10, 05:39 PM
salimshah
salimshah's Avatar
Engine knock pops up CEL, so do you have one?
Salim
Old 02-26-10, 08:44 PM
silvertn35
silvertn35's Avatar
what weight oil are you using? sure its not lifter tick? a knock and a tick sound pretty different though.
Old 02-26-10, 09:10 PM
carguy07
carguy07's Avatar
Don't these cars have solid lifters that are shimable?
Old 02-26-10, 11:53 PM
code58
code58's Avatar
Carguy- I think you just might be right.
Old 02-27-10, 02:30 AM
artbuc
artbuc's Avatar
Yes, solid with shims.
Old 02-27-10, 09:07 AM
salimshah
salimshah's Avatar
I was under the impression that they are hydraulic lifters which take some time to fill up and the chatter goes away. Now need to come up with another explanation for the cold morning chatter with wider wider range engine oil (W weight).
Salim
Old 02-27-10, 04:42 PM
Nad1370
Nad1370's Avatar
Artbuc , code58 and carguy are right.
These are solid lifters that are shimmable if the clearance is too big.
I think the "GR" motor in the 350 are hydraulic though.
The OP stated it was a "knock".
Which leads me to believe something is broken or severely worn.
Hopefully it's a "tick" or a "tapping" noise instead.
Old 02-27-10, 06:38 PM
Lexmex
Super Moderator
Lexmex's Avatar
Are any of you noticing any chatter/ticking/tapping in cold weather?
Old 02-27-10, 10:52 PM
salimshah
salimshah's Avatar
I have had chatter in the winter months. I have recently replaced the knock sensors and the weather has warmed up. [My cel kept coming back during Dec and Jan]. I will monitor and report back.
Salim
I8ABMR
IS F (2008-2014)
21
09-29-17 08:09 AM
sixonemale
09-11-15 08:13 AM
gtknoles
03-12-14 02:31 PM
DosyBoy
06-28-12 12:14 AM
Woogie
01-16-05 10:43 PM
Quick Reply: engine knock
