Heated Seat Not Working
Old 01-04-10, 09:13 AM
lexitaxi
lexitaxi's Avatar
Default Heated Seat Not Working
Here's the situation.... the driver's side heated seat cushion (bottom) is not working, however the seat back warmer (lower back) is working. The passenger's side is fine. Looked under the seat to see if the snow brush accidentally disconnected a wire, but didn't see anything loose.
Any ideas? I'd figure if it was a fuse, the entire driver's seat wouldn't heat along with the passenger's as well if they were on the same circuit.
Looking forward to a warm posterior again.....
Old 01-04-10, 10:42 AM
ByTor
ByTor's Avatar
Heating element is burned out. Replacement needed, not sure if you can buy them sepaerately, check with your local stealer.
Old 01-04-10, 06:10 PM
sktn77a
sktn77a's Avatar
A good uphostery shop should be able to replace the seat cushion element only.
Old 01-05-10, 05:38 AM
lexitaxi
lexitaxi's Avatar
Thanks for the recommendations. I was affraid it would be the element. Priced a new one out, they are surprisingly expensive!
Old 01-05-10, 10:04 AM
sktn77a
sktn77a's Avatar
Yes, the Lexus element will be expensive but you can use an aftermarket one at a fraction of the cost.
Old 01-06-10, 05:34 PM
trhs75
trhs75's Avatar
Or buy a factory one online from one of the online dealers advertised here. When I bought them about two years ago, the lower cushion element (part # 87510-48011 -- same for L or R) retailed for about $410 and cost me $307 plus shipping from mylexusparts.com. It's a time-consuming job, but doable. You need some hog ring pliers and a special Lexus tool to fasten the seat heater onto the back of the upholstery. It uses little plastic things like the ones which attach price tags to clothing.
Old 01-07-10, 03:33 PM
sktn77a
sktn77a's Avatar
Should cost an upholstery shop about $50 for the element (aftermarket) and $100 to replace it.
Old 01-07-10, 06:12 PM
trhs75
trhs75's Avatar
The professionals must work a whole lot faster than I do -- not surprising!!
Old 01-27-16, 07:27 PM
philnshelb
philnshelb's Avatar
Default passanger seat heat cool inop
I am reading here about an element but my turnknob to activate the passanger side doesnt light up. Does anyone know if there is a particular fuse for just the passanger side?
Old 01-28-16, 10:45 AM
sktn77a
sktn77a's Avatar
Is this in an RX300, or in your LS?
Old 01-28-16, 11:14 AM
philnshelb
philnshelb's Avatar
Sorry didnt realize i posted this in a different generation. but i was referring to our 460
Old 01-28-16, 01:14 PM
salimshah
salimshah's Avatar
Different vehicle too.. Moving
midwest2
07-19-21 04:13 AM
PAVGR
01-08-11 02:19 PM
Matt92SC40
SC400 / 300 Classifieds
05-20-07 09:42 AM
mjtous1
SC- 1st Gen (1992-2000)
03-30-06 11:55 PM
Integrator
01-21-03 12:35 AM
Quick Reply: Heated Seat Not Working
