installing speakers on rx 300's 330's 99-02
Old 04-12-11, 04:55 AM
JAB
JAB's Avatar
No but I will. I did find an eBay seller with one, however. Thanks.
Old 03-23-15, 07:33 PM
slimguy221
slimguy221's Avatar
How do i get the door speakers out?Do i have to remove the door panel?
Old 03-23-15, 08:49 PM
mizak82
mizak82's Avatar
yes.. remove the door panels.. those speaker covers are attached to the door... they don't come off..
its pretty straight forward..
I used JL audio door speakers.. 6 3/4 up front... 6 1/2 in the back doors.. My stock ones were so fried they had no surround left on them.. Huge improvement.. You will also need the speaker mounts to go with them.. Unless I am mistaken, but i thought the stock speakers and mounts are one piece..
Old 03-24-15, 07:06 AM
ecerdas
ecerdas's Avatar
take a look at one of my pics some messages back, there is a pic of the front Nakamichis and the door without the door panel.
Old 03-27-15, 06:18 AM
Bobster999
Bobster999's Avatar
When i bought my RX a few years ago, I installed Infinity speakers all around and using components up front. Couple those with a GROM unit and I have been very pleased with my sound and i spent very little money while doing the work myself which most anyone can do.
Old 09-06-15, 09:57 AM
Telones
Telones's Avatar
Default Aftermarket powered amp for sub
How would I go about taking the sub lines from the original factory amp, and route them into an RCA input amp? I've already exposed everything from the rear to get to the factory amp. My amp that I currently have to put in for the sob is a line input RCA style I need to figure out which wires I need to splice into and make them into an RCA format. Any help or recommendations would be awesome.
Old 07-09-19, 03:18 PM
Spelljamme
Spelljamme's Avatar
you can use a simple voltage divider circuit, just two resistors, a 10k and a 1k.
Old 05-02-20, 02:54 PM
Djpoint
Djpoint's Avatar
Default speakers
speakers
fyi....update, those infinity 6032 are no longer available. Crutchfield says polk audio 652db are replacements. Also do i have to replace all four? 2ways? Wont that be overkill on the high end?
Edit
tftimm
SC- 1st Gen (1992-2000)
07-15-11 06:38 AM
DMM100
12-25-10 07:48 AM
sarah
07-22-09 10:01 PM
CleanSC
08-25-04 09:00 AM
Quick Reply: installing speakers on rx 300's 330's 99-02
