Brake light, replaced it, still doesn't work
So I had a brake light go out on my '03 rx300, it's the driver side light on the hatch.
I swapped out the bulb, still didn't work, I even switched the bulbs from the passenger to the driver (just to make sure it wasn't a wrong bulb problem), still didn't work.
Could someone advise me if there is a fuse or something I should check?
Thanks!
Thanks!
I dont have the circuit diagram for RX, but typically left and right electrical stuff is not on different fuse. So if my assumption is correct, since one works the fuse will be ok.
The bulbs have a wire that is folded back. Makes sure the position of the wire on the bulb is correct .. use needle nose pliers to align it in the middle of the flat.
You may have to trace the wire-harness.
Salim
Salim
Darrenbret
RX - 1st Gen (1999-2003)
06-21-16 03:17 AM
