10-20-09, 06:26 PM
Is this a rear main seal leak?
I've done a search and I'm pretty sure this is a rear main seal problem. Seems people have tried Auto-RX and that slowed or stop it with some owners.
Questions I couldn't find the answer to: Could having your timing belt changed cause this?
Had my T-belt, P/S belt, water pump and radiator flushed a bit more then 3 months ago and since driven under 4K miles.
Before I had the T-belt, water pump...etc.. done, the car was tight as a drum. Any chance the dealership forgot to tighten something?
Tags
2000, fluid, gx470, leak, leaking, leaks, lexus, main, oil, rear, rx300, sc300, seal, suspension, type  |
| Thread Tools |
| Display Modes |
Threaded Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
