Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Thread Tools Display Modes
Old 09-11-09, 07:51 PM   #1
adi
Trader Score: (0)
Default Anyone have seen this problem on a RX 300 ?
Hi everyone,I was wondering if anybody can give me an advice regarding my wife's car RX 300 '99. First she noticed that the remote control didn't work , but because it happened in the past,she just lock the doos manually. Minutes later when she was in a parking lot ready to leave the car and the keys were in her hand she noticed some lights (TRAC Off, ABS, and some other lights were blinking intermitently like a short circuit) and made a noise similar with the car alarm but softer.She got concern she turn on and off the engine which worked properly. At one point the whole dash board had the lights on,exacly like when someone tries to turn on the ignition, but the keys where in her hand. The car runs perfectly when the keys are in the ignition though.When I take the key out of the ignition the ABS light is blinking on/off(like a short circuit ) and is very dim.I should add that about a week ago her car was towed for illegal parking. Could they have messed up something while towing the car?
Thank you for sharing your thoughts.
adi is offline   Reply With Quote
Old 09-11-09, 07:57 PM   #2
galletgun
Trader Score: (0)
I dont think its your fuel injector cleaner b/c I put fuel injector cleaner in my 2001 rx300 and also in my 2003 is300. The only thing I can suggest, which could be a quick fix is to disconnect your negative battery cable for 10 minutes. Hook up your battery and see if the problems till persists.
galletgun is offline   Reply With Quote
Old 09-12-09, 06:48 AM   #3
sktn77a
Trader Score: (0)
sktn77a's Avatar
You can get funky stuff like this happening when the alternator/battery is bad. (I had it a while back when they forgot to tighten the alternator belt and it just wasn't turning the alternator).
__________________
Keith
2008 Lexus IS250
1999 Lexus RX300 4WD
2001 BMW 530i
1997 Geo Prizm LSI
2005 Toyota Prius
sktn77a is offline   Reply With Quote
Old 09-12-09, 07:36 AM   #4
mikey00
Trader Score: (0)
My first thought would be to just change the battery and see if the problem goes away. Batteries are cheap enough for it to be a cost effective way of troubleshooting. You're probably about due for a battery anyway, right? But the fact that your car was just towed makes me suspicious. Did they gain entry to tow it? If so I wonder how they did.
mikey00 is online now   Reply With Quote
Old 09-12-09, 10:03 AM   #5
salimshah
Trader Score: (0)
Some times the "strange" behavior can be fixed by resetting the electronics by battery disconnect for 20 mins or so. Warning ,,, this also clears the personalized settings of radio and seat.
Salim
salimshah is offline   Reply With Quote
Old 09-14-09, 08:50 AM   #6
mikeburnet
Trader Score: (0)
sounds like a bad battery
mikeburnet is offline   Reply With Quote
Tags
2000, abs, alarm, blinks, es300, fuel, injector, lexus, light, problem, problems, rx300, show, tow, trac
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
