Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Thread Tools Display Modes
Old 08-27-09, 07:16 AM   #1
Boergy
Trader Score: (0)
Boergy's Avatar
Default Difference between 99 and 2000 RX Snow/Power and Snow Button
Hello!
I have seen, the ´99 RX300 have a switch with snow/power. and the 2000 up only a button for snow. I think, this is come with the face-lift.
But what is different? Snow is to start in the 2nd Gear, ok. But POWER? Shift the transmission faster? I read many ´99 RX have defect transmissions. Is this the problem, why Lexus have this switch no longer in the face-lift?
Have one member both models driven to feel a difference?
Switch ´99:
Button ´00:
Thanks for the answers!
greets
Tom
__________________
04/2001 Lexus RX300 4WD Opal Green Metallic, Rear Spoiler, Black Leather, Navigation, Privacy Glass
Mods: ACCEL Kool Blue Air Filter - Mobil1 5W50 Oil - Denso IK20 Plugs - Delta 4x4 Duplex Exhaust - TTE Springs - Kayaba Ultra SR Damper - Aeroflat Wipers - Narva 4100K Frontlamps - 2500K Fog Lamps - TTE 17x7,5" nine spoke screw design Alloy Wheels ”Chicane” - Clear smoked side Markers - Tinted Windows - LED Domelight - Pioneer Class A Amp - Pioneer Subwoofer - Philips GTM Tweeter
Boergy is offline   Reply With Quote
Old 08-27-09, 12:44 PM   #2
JiBBeL
2002 Lexus RX
My Garage
Trader Score: (1)
JiBBeL's Avatar
The PWR setting tells the transmission to hold its gear for longer, and climb up in the RPM range higher before upshifts. It's good for a slightly more sporty feel to the transmissions shift point map.
In the US, the 00' model still had the PWR and snow mode switch. It wasn't until 2001 that they discontinued the PWR setting. Why did they get rid of it? Your guess is as good as mine, but probably not because of the transmission problems that plagued early models. It's probably because not many owners of the RX model would ever use it.
__________________
01' GS430 - Espelir Springs - KYB GR-2 Shocks - TRD Blue Sway Bars - M3 Lip Spoiler - DIY Chrome Grill - BBS RK Wheels - Falken Ziex 912 Tires
02' RX300 AWD - Coach Edition - HID
JiBBeL is offline   Reply With Quote
Old 08-27-09, 01:11 PM   #3
Boergy
Trader Score: (0)
Boergy's Avatar
thanks for the answer!
Maybe its possible to modify a 2001 RX with this funktion? i have only the 2001 wiring diagramm
__________________
Old 08-27-09, 01:41 PM   #4
lexus114
Trader Score: (0)
lexus114's Avatar
Not worth all the hassle.
__________________
lexus114 is offline   Reply With Quote
Old 08-27-09, 01:48 PM   #5
Boergy
Trader Score: (0)
Boergy's Avatar
aha ok, i know the diffence in IS300, GS430, SC430, but this all 5 oder 6 speed A/T.
ok...next project
__________________
Old 08-27-09, 02:55 PM   #6
Lexmex
Trader Score: (0)
Lexmex's Avatar
The PWR button was nice for racing. I'll have to take a look late tonight in my 99 RX Manual, but I have a hunch the ECU programming might be involved among other things, which would make such a project a real pain to do.
What I always wanted from the Toyota Harrier was the tiptronic function where once you were in Drive, you could shift up and down gears. Having that and also the PWR button would have been fantastic.
__________________
Homepage of my 1999 RX300 AWD
Lexmex is offline   Reply With Quote
Old 08-27-09, 05:57 PM   #7
salimshah
Trader Score: (0)
My impression was that it was removed to show an improved emission spec. Then the engine size went up and the performance advantage/loss was recovered.
Salim
salimshah is offline   Reply With Quote
Old 08-28-09, 04:51 AM   #8
Boergy
Trader Score: (0)
Boergy's Avatar
HY!
i have searched in the www and found 3 types of Engine in the RX300/Harrier
ACU10
ACU15
MCU10
MCU15
SXU10
SXU15
ACU= 2AZFE: 2400CC 16VALVE DOHC EFI
MCU=1MZFE: 3000CC 24-VALVE DOHC EFI
SXU= 5SFE: 2200CC 16-VALVE DOHC EFI
xxx10= FWD
xxx15= AWD
here a interior of a 2,2L Harrier.
on toyo-diy are the transmissions-partnumber only different on the last 2 digits. and looks like the same.
with a wiring diagramm was easer to find a solution, but i think, its different transmissions-ECU in the cars. to modify, i think we need the gauge cluster, shift lever, steering wheel and may cables and bits and pieces.
3 Gears + O/D is ok without shift-padels, a 5-gear transmission was better with padels. I have see in the GS430 S16 no shift padels but he have 5 gears and enough power i hear, its no good for the 5-gear transmission
__________________
Old 08-28-09, 08:21 AM   #9
lexus114
Trader Score: (0)
lexus114's Avatar
HY!
ACU10
ACU15
MCU10
MCU15
SXU10
SXU15
xxx10= FWD
xxx15= AWD
Man,that just does not look right that way (drivers side on pass.side)
__________________
Old 08-28-09, 08:31 AM   #10
Lexmex
Trader Score: (0)
Lexmex's Avatar
Quote:
In Japan they drive on the left side just like the U.K.
I saw the same thing when I went to Jamaica and they had Harriers there just like this configuration.
__________________
Old 08-28-09, 07:50 AM   #11
Lexmex
Trader Score: (0)
Lexmex's Avatar
There were I think 2 Lexus forums in Russia, and I can't remember on which, but I was reading through Google Translate on an attempt to retrofit the tiptronic function shown in the picture above. I am not sure if it was successful, but I do remember the thread went on for a bit and never found out the result.
__________________
Tags
2002, 4wd, button, figures, gear, gs300, harrier, lever, lexus, mcu10, performance, power, rx300, snow, toyota
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
